LWPOLYLINE entmake
LWPOLYLINE entmake
mmitchellH6TRW
LWPOLYLINE entmake
mmitchellH6TRW
This is mainly a list processing question.
Please help create the LWPOLYLINE entlist for entmake:
;; LWPOLYLINE.lsp
;; test for LWPOLYLINE creation
(defun test ()
  (setq plverts '((1 2) (2 3) (5 6))
        plbulg  (0.0 0.5 0.0)
        entdef  (append
                  (list
                    '(0 . "LWPOLYLINE")
                    (cons 8 0)
                    (cons 67 0)
                    '(100 . "AcDbPolyline")
                    (cons 90 (length plverts))
                    (cons 70 0)
                    (cons 43 0.0)
                    (cons 38 0.0)
                    (cons 39 0.0)
                  (mapcar ; this is the peice that doesn't work
                    '(lambda (#10 #42)
                       (list
                         (cons 10 #10)
                         (cons 42 #42)
                    plverts
                    plbulg
                 (list
                  (cons 210 (0.0 0.0 1.0))
  (princ entdef)
  (entmake entdef)
ВeekeeCZ
5 issues.
BTW It's good to always start HERE
(defun c:test ()
	plbulg  '(0.0 0.5 0.0) ; !
	entdef  (append
		  (list
		    '(0 . "LWPOLYLINE")
		    (cons 8 "0") ; !
		    (cons 67 0)
		    (cons 100 "AcDbEntity") ; !
		    (cons 70 0)
		    (cons 43 0.0)
		    (cons 38 0.0)
		    (cons 39 0.0)
		  (apply 'append ; !
			 (mapcar
			   '(lambda (#10 #42)
			      (list
				(cons 10 #10)
				(cons 42 #42)
			   plverts
			   plbulg
		  (list
		    (cons 210 '(0.0 0.0 1.0)) ; !
  (princ entdef)
  (entmake entdef)
hak_vz
If you want to use visual lisp
(defun make_lw_poly (plverts plbulg / adoc space newline i)
	(setq adoc (vla-get-ActiveDocument (vlax-get-acad-object)))
	(setq space
		(if (zerop (vla-get-activespace adoc))
			  (if
				(= (vla-get-mspace adoc) :vlax-true)
					(vla-get-modelspace adoc)
					(vla-get-paperspace adoc)
	(if (= (length (car plverts)) 2)
		(setq plverts (apply 'append plverts))
		(setq plverts (apply 'append (mapcar '(lambda (x) (list (car x) (cadr x))) plverts)))
	(setq newline
		(vla-addlightweightpolyline space
			(vlax-make-variant
				(vlax-safearray-fill
					(vlax-make-safearray vlax-vbdouble (cons 0 (1- (length plverts))))
						plverts
   (setq i -1)
   (while (< (setq i (1+ i)) (length plbulg))
		(vla-SetBulge newline i (nth i plbulg))
(setq
(setq lw (make_lw_poly plverts plbulg))
Miljenko Hatlak
john.uhden
@hak_vz
That's sorta like my style, but I got into the habit of building the list of vertices as...
(setq plist '((b1 x1 y1)(b2 x2 y2)...(bn xn yn))  ;; No, I don't use variables like b1, x1, etc.
Then add a LWPolyline with just two random vertices (or maybe even just one, but I don't remember) and then
(vlax-put object 'Coordinates (apply 'append (mapcar 'cdr plist)))
and
(setq i -1)
(repeat (length plist)(vla-setbulge object (setq i (1+ i))(car (nth i plist))))
That way it's easy to add or remove a vertex (including bulge) to/from plist.
I think my VEDIT and 3DEDIT command functions work that way, with the obvious difference that LWs are only (x y) but have bulges, and 3Ds are just (x y z).
That's where my @group function comes into play...
   ;; Function to group a list ofitems into a list of
   ;; multiple lists, each of length N, e.g.
   ;; '(A B C D E F G H I) -> '((A B C)(D E F)(G H I))
   (defun @group (lst n / item new)
     (foreach element (reverse lst)
       (setq item (cons element item))
       (if (= (length item) n)
         (setq new (cons item new) item nil)
     new
John F. Uhden
