LW Polyline Vertex
LW Polyline Vertex
Message 1 of 8
LW Polyline Vertex
Hello
I have hundreds of polylines in my file . Every polyline has 3 vertex (x,y). I would like to modify vertex no 3 to have same y coordinates as vertex no 2. Is any simple way to do it ?
Thanks for help
Replies (7)
Message 2 of 8
Kent1Cooper
Reasonably simple.  Pull the Coordinates VLA property, put its 4th entry in again in place of the last one, and apply that new Coordinates list to the Polyline.  Try this [minimally tested]:
(defun C:3rdY (/ ss n obj co)
  (if (setq ss (ssget '((0 . "LWPOLYLINE"))))
    (repeat (setq n (sslength ss)); then
      (setq
        obj (vlax-ename->vla-object (ssname ss (setq n (1- n))))
        co (vlax-get obj 'Coordinates)
      ); setq
      (vlax-put obj 'Coordinates (reverse (cons (nth 3 co) (cdr (reverse co)))))
    ); repeat
  ); if
  (princ)
); defun
(vl-load-com)
Kent Cooper, AIA
Message 3 of 8
Great It works perfect 🙂
Message 4 of 8
Kent1Cooper
Good.  Of course you understand that it's very specific to 3-vertex Polylines, and if any other kind gets selected, the result will probably not be what you intend.  It could be made to limit selection  to only those with 3 vertices, to avoid unexpected effects on Polylines you didn't want to change.
If you might sometimes need to do the same on longer ones, it could be adjusted so that [for example] it changes the Y coordinate of the last  vertex to be the same as that of the next-to-last  one, no matter how many there are.
Kent Cooper, AIA
Message 5 of 8
Yes I know this is for this particular case. These polyline  are always the same in my files.
This is the perfect solution to my problem. Fast and effective 🙂 Thanks
Message 6 of 8
CodeDing
@Kent1Cooper / @Anonymous ,
This can also easily be accomplished without VisualLisp by using the get.../setpropertyvalue functions. People often forget that these functions have the ability to access collections inside the entity. Kent's answer works fine, this is just an alternative approach.
(defun c:TEST ( / ss e cnt)
    (repeat (setq cnt (sslength ss))
      (setq e (ssname ss (setq cnt (1- cnt))))
      (setpropertyvalue e "Vertices" 2 "Position/Y" (getpropertyvalue e "Vertices" 1 "Position/Y"))
    );repeat
  );if
  (prompt "\nComplete.")
  (princ)
);defun
Best,
DD
Message 7 of 8
ВeekeeCZ
  (if (setq ss (ssget '((0 . "LWPOLYLINE") (90 . 3))))
    );repeat
  );if
  (princ)
);defun
Best,
DD
... as a minimum for error prevention. But +1 for the simplicity.
Message 8 of 8
Sea-Haven
Nice idea for anyone using Bricscad does not support get or set property. Kent Cooper works.
