#<VLA-OBJECT IAeccPoint3d
ebarlevi
Message 1 of 10
ebarlevi
I am trying to obtain the value of a point (the position of a civil 3d structure) like that:
(setq obj (vlax-ename->vla-object (car (entsel))))
(setq p1 (vlax-get-property obj 'Position))
I get:
#<VLA-OBJECT IAeccPoint3d 00000270e7ca4760>
My question:
How to proceed from here to obtain the value of the point?
Eitan
Replies (9)
Message 2 of 10
pbejse
This should give you the value on a point in list format. If position is available as properties for obj
(vlax-get obj 'Position)
If not, you can always see what properties are available for any entity using
(vlax-dump-Object obj)
Otherwise, post a drawing sample and tell us more on what you're after
Message 3 of 10
hosneyalaa
(setq p1 (LIST (vlax-get-property (vlax-get-property obj'Position) 'X)(vlax-get-property (vlax-get-property obj'Position) 'Y) (vlax-get-property (vlax-get-property obj'Position) 'Z)))
Message 4 of 10
hosneyalaa
If you have questions
About civil 3d
from herehttps://forums.autodesk.com/t5/civil-3d-customization/bd-p/190
Message 5 of 10
hak_vz
Dive into AECC point definition end extract what you need. I don't use Civil 3d so I can't help you directly
 but you can:
(vlax-dump-object p1 T) and extract properties and methods of AECC point-
(setq pt (vlax-invoke-method p1 'Getpoint)) or
(setq x (vlax-get p1 'x))
(setq y (vlax-get p1 'y))
(setq z (vlax-get p1 'z))
Check developers help in Civil 3d or check this link
Miljenko Hatlak
Message 6 of 10
ebarlevi
Thanks a lot.
Exactly what I needed.
Eitan
Message 7 of 10
hosneyalaa
SEE THIS
https://forums.autodesk.com/t5/civil-3d-customization/export-data-from-the-pipenetworks-to-csv/m-p/10335982#M20165
Message 8 of 10
calderg1000
Hello @ebarlevi
Maybe this will help. If I already solve it, that's good; then don't take it into account.
(defun c:Coords()
(setq msp(vla-get-modelspace(vla-get-activedocument(vlax-get-acad-object))))
	p1 (vlax-safearray->list(vlax-variant-value(setq plv(vlax-get-property obj 'Location)))))
(vla-addtext msp (strcat" E:"(rtos(nth 0 p1)2 3)" N:"(rtos(nth 1 p1)2 3)" Z:"(rtos(nth 2 p1)2 3)")") plv 2)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 9 of 10
Sea-Haven
As you implied a Civ3d object you should select then check what is it, vla-get-objectname, use a cond to say get position, if its say a aeccogopoint better using a ssget with correct filter.
Message 10 of 10
calderg1000
Select only Cogo points
(defun c:Coords (/ msp s i obj p1 plv)
  (setq	msp (vla-get-modelspace
	      (vla-get-activedocument (vlax-get-acad-object))
  (if (setq s (ssget '((0 . "aecc_cogo_point"))))
    (repeat (setq i (sslength s))
      (setq obj	(vlax-ename->vla-object (ssname s (setq i (1- i))))
		  (vlax-variant-value
		    (setq plv (vlax-get-property obj 'Location))
      (vla-addtext
	msp
	(strcat	" E:"
		(rtos (nth 0 p1) 2 3)
		" N:"
		(rtos (nth 1 p1) 2 3)
		" Z:"
		(rtos (nth 2 p1) 2 3)
	plv
	2
    (princ "Pts. not selected. COGO; Repeat Selection ...:")
  (princ)
Carlos Calderon G
