lsp to load or reload all linetypes from .lin file
demus72
Message 1 of 9
demus72
I've done some research but haven't found quite what I'm looking for.
The company I work for stores all their linetypes in a custom .lin file. This collection of linetypes is relatively complete but on occasion, we may modify an existing linetype or add a new one. I'm looking for a lisp routine that will load or reload all linetypes from a .lin file.
Replies (8)
Message 2 of 9
ronjonp
Try this:
(defun _loadlt (/ ex v va)
  (setq va (mapcar 'getvar (setq v '(cmdecho expert))))
  (mapcar 'setvar v '(0 5))
  (foreach lt (if (= 0 (getvar 'measurement)) ; <-Imperial
		;; Add your custom files to the list, if not in search path provide the full path
		'("acad.lin")
		;; Metric
		'("acadiso.lin")
    (and (findfile lt) (command "._-linetype" "_Load" "*" lt ""))
  (mapcar 'setvar v va)
  (princ)
(_loadlt)
Message 3 of 9
Kent1Cooper
Try this [untested]:
(defun C:LAL (); = Load All Linetypes
  (command "_.linetype" "_load" "*" "YourLinetypeFileName.lin"); leaves in command
  (while (> (getvar 'cmdactive) 0) (command "")); Enters until finished
The "Enters until finished" would accept the Yes default for reloading any linetype(s) already in the drawing, and the end-the-command final Enter when there are no more of those.
Edit the "YourLinetypeFileName" part to suit.  A file path can be included, if you don't have it in a folder that's in your Support File Search Path list.
Kent Cooper, AIA
Message 4 of 9
demus72
Thank you both for your replies and your willingness to offer your lisp coding expertise. Very cool! Both lsp files performed exactly what I was looking for.
Thanks again and have a great day!
Message 5 of 9
Sea-Haven
Another loads individual line types
(defun loadLinetype (doc LineTypeName FileName)
  (if (and
        (not (existLinetype doc LineTypeName))
        (vl-catch-all-error-p
          (vl-catch-all-apply
            'vla-load
            (list
              (vla-get-Linetypes doc)
              LineTypeName
              FileName
    nil
    T
(defun existLinetype (doc LineTypeName / item loaded)
  (vlax-for item (vla-get-linetypes doc)
    (if (= (strcase (vla-get-name item)) (strcase LineTypeName))
      (setq loaded T)
;load missing linetypes
;;; returns: T if loaded else nil
(loadLinetype doc "Fence" "custom.lin")
(loadLinetype doc "Tree" "custom.lin")
(loadLinetype doc "Water_main" "custom.lin")
(loadLinetype doc "Gas_main"  "custom.lin")
Message 6 of 9
R_Tweed
Is it possible to add multiple .lin files to your routine?
Message 7 of 9
Kent1Cooper
Yes.  You could just repeat lines 2 & 3 with a different file name in each copy of line 2.  Or if you have the file names in some kind of format [an AutoLisp list? a spreadsheet file?  a plain text file?], presumably it could be made to step through that information and apply the file names within line 2 without having to spell that out separately for each one.
Kent Cooper, AIA
Message 8 of 9
R_Tweed
(command "_.linetype" "_load" "*" "Av-Site.lin"); leaves in command
(command "_load" "*" "Av-Streets.lin"); leaves in command
(command "_load" "*" "Av-Utilities.lin"); leaves in command
Thanks! The above works nicely.
Message 9 of 9
Sea-Haven
Make sure save inside a DWT then no need to do again till next addition.
