Lsp Intersection:Line/Pline
I need your support,
I created the following program to draw a point at each intersection between tow lines
I want to update it to draw the edit points when I have two polylines or line / polyline
(defun c:IN2L (/ l1 l2 intersection a)
(setq l1 (car (entsel "\npoligne 1"))
        l2 (car (entsel "\npoligne 2"))
(setq intersection (inters (list (car (cdr (assoc 10 (entget l1))))
                                            (cadr(cdr (assoc 10 (entget l1)))))
                                      (list (car (cdr (assoc 11 (entget l1))))
                                            (cadr (cdr (assoc 11 (entget l1)))))
                                      (list (car (cdr (assoc 10 (entget l2))))
                                            (cadr(cdr (assoc 10 (entget l2)))))
                                     (list (car (cdr (assoc 11 (entget l2))))
                                           (cadr (cdr (assoc 11 (entget l2)))))
                            nil)
(command "point" intersection "")
Thank you in advance,
cig_ad
You can try something like this:
(vlax-safearray->list (vlax-variant-value (vla-IntersectWith (vlax-ename->vla-object ename1) (vlax-ename->vla-object ename2) acExtendNone)))
which will return a single dimension list that you can group as points (remember - there can be multiple intersections).
see also: http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-1243A593-5DAE-4DC3-B539-59FDA990E687
ВeekeeCZ
Maybe like this,
(defun C:In2ob ( / ss ptsa pt)
  (if (and (setq ss (ssget '(( 0 . "LINE,LWPOLYLINE"))))
	   (= 2 (sslength ss))
	   (setq int (vLa-intersectwith (vLax-ename->vLa-Object (ssname ss 0))
		       			(vLax-ename->vLa-Object (ssname ss 1))
		       	            	acextendnone))
	   (setq ptsa (vLax-safearray->List (vLax-variant-vaLue int))))
    (repeat (/ (length ptsa) 3)
      (setq pt (list (car ptsa)
		     (cadr ptsa)
		     (caddr ptsa)))
      (command "_.POINT" pt)
      (setq ptsa (cdddr ptsa))))
  (princ)
Used part of stevor's code here
Perfect Smiley Happy
That is exactly what I need.
Thank you for the support
I have a question more ... I take advantage.Smiley Happy
It is necessary to go through this formula vLa-intersectwith (vLax-ename->vLa-Object (ssname AA 0))
(vLax-ename->vLa-Object (ssname AA 1))acextendnone)
No other shorter and simpler (classic) method?
Thank you for your answers
