.lsp file for editing attribute field to display todays date
mark.d.beardmore
mark.d.beardmore
Morning all,
I'm trying to find a .lsp file that will let you click an attribute field, and replace the present value with todays date in the following format
DD/MM/YY
It might also be useful to have one which is in this format also
DD/MM/YYYY
I assume this is just a slight change to the lisp code?
Does anyone have these?
Mark
ВeekeeCZ
Guess it's just an attribute with plain text, not a (dynamic) field.
Post a sample block.
mark.d.beardmore
Yes just a standard block & field
I've attached an example
ВeekeeCZ
Sure, as simple as that.
(defun c:Adate2 ( / d e) (if (setq d (itoa (fix (getvar 'cdate))) e (car (nentsel "Select attribute: "))) (setpropertyvalue (cdr (assoc 330 (entget e))) (cdr (assoc 2 (entget e))) (strcat (substr d 7 2) "/" (substr d 5 2) "/" (substr d 3 2)))) (princ) ) (defun c:Adate4 ( / d e) (if (setq d (itoa (fix (getvar 'cdate))) e (car (nentsel "Select attribute: "))) (setpropertyvalue (cdr (assoc 330 (entget e))) (cdr (assoc 2 (entget e))) (strcat (substr d 7 2) "/" (substr d 5 2) "/" (substr d 1 4)))) (princ) )
mark.d.beardmore
That worked perfectly, thanks so much
