lsp error
lsp error
lsp error
hello, I made it, but does not working. what is the problem.
(defun c:ff (/ ss pe )
 (princ "text, mtext size:")
  (setq ss (ssget ":s" '((0 . "*TEXT"))))
  (setq pe (entget (ssname ss 0)))
  (setq pe (cdr (assoc 40 pe)))
(alert (strcat "\n" "dtext, mtext size " pe "\n  "))
(princ)
cadffm
; the next line of code you get an error message if you selected nothing: ; error: bad argument type: lselsetp nil
; the next line of code you get an error message because STRCAT want only STRINGS, but the value of dxf-code 40 is a REAL, not a STRING: ; error: bad argument type: stringp nil
(princ)
(if (setq ss (ssget ":s" '((0 . "*TEXT"))))
    (progn
       (alert (strcat "\n" "dtext, mtext size " (rtos pe 2) "\n "))
(princ)
I could edit more thing, but for the start it should be enough.
Read about IF PROGN and RTOS in your Help[F1]
Sebastian
Shneuph
; error: bad argument type: stringp 0.2
You are passing pe of data of type real and lisp is expecting a string.  Use:
(alert (strcat "\n" "dtext, mtext size " (rtos pe) "\n "))
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
thank you...
