Loop ray command
Loop ray command
Philip-John
Loop ray command
Philip-John
I need a lisp routine to draw ray lines and that should draw multiple ray lines with separate start point where I click until I press Escape key. I have a code as follows. But it takes same start point for each click. Can some help me to modify this routine.
(defun c:RayLoop (/ pt1 pt2)
(while (setq pt1 (getpoint "\nSelect the start point for the ray: ")) ; Continue until the user cancels
(setq pt2 (getpoint pt1 "\nSelect the direction point for the ray: ")) ; Get the direction point
(if pt2
(command "ray" pt1 pt2) ; Execute the ray command
(princ "\nRay loop ended.")
(princ)
ВeekeeCZ
(if pt2
(command "ray" pt1 pt2 "") ; Execute the ray command
(princ)
Add "" there... ?
Philip-John
Thanks a lot brother.
It works as I wish..
ВeekeeCZ
Or try this version with a better preview.
(defun c:RayLoop (/ pt1 )
    (command "ray" pt1 pause "")) ; Execute the ray command
  (princ)
BTW you shouldn't exit the command by ESC.. or at least you don't have to. I would consider that as a bad habit. Most built-in commands are designed to be ended by RT click. This routine as well.
Philip-John
Oh great..
Even better than the previous one as you said.
Thanks bro
annoisscary
This is simple enough that it doesn't even really need to be a lisp. You could make this as a Shortcut Key or Button in CUI easily.
*^C^C_ray;\\;
Philip-John
Perfect (Without lisp)
Thanks brother.
