Looking to match x and y coordinates of polylines then perform a specific action
Hello to all:
I am using LISP routines to send geometry in a block to various layers depending on certain conditions.  I am stuck at this issue:  I want to send a closed polyline with 4 vertices to one of two layers based on the following criteria:
If the y-coordinate of the first vertex matches the y coordinate of the second vertex,
-then put the polyline object on the "ROLLERS" layer
Else if the x-coordinate of the first vertex matches the x coordinate of the seCond vertex,
-then put the polyline object on the "FRAMES" layer
Here's how it would fit in my program:
(setq ymatch (cdr(vlax-get b 'coordinates)) ;;NOT SURE ABOUT THIS PART IN PARTICULAR
;;getting each line/polyline object
(cond ;;applying conditions here
((and (vlax-curve-isclosed b)
(equal vnum 4)
(????) if the Y-coordinate of the first vertex matches the Y coordinate of the second vertex
;;the object is a closed polyline WITH 4 VERTICES MATCHING THE FIRST CONDITION MENTIONED ABOVE
(addprop b "HILMOT-CONV-BLK-ROLLERS")
;; then add to this layer
(equal vnum 4)
(????) if the X-coordinate of the first vertex matches the X coordinate of the second vertex
;;the object is a closed polyline WITH 4 VERTICES MATCHING THE SECOND CONDITION MENTIONED ABOVE
(addprop b "HILMOT-CONV-BLK-FRAMES")
Does my request make sense?  Basically...
 If the Polyline resembles a telephone pole standing up, it should go on the "ROLLERS" layer
 If the Polyline resembles a telephone pole laying on the ground, it should go on the "FRAMES" layer
Thanks for any help in this matter!
Kent1Cooper
Because the 'Coordinates VLA Property is just an un-divided list of coordinate values, (cdr) on it is going to give you the whole list minus only the first X coordinate.  I think it would be easier to pull coordinates from the first two vertices as start-point and parameter-1 values:
(if (and (vlax-curve-isClosed b) (= vnum 4))
  (cond
    ((equal (cadr (vlax-curve-getStartPoint b)) (cadr (vlax-curve-getPointAtParam b 1)) 1e-4)
    ); same-Y condition
    ((equal (car (vlax-curve-getStartPoint b)) (car (vlax-curve-getPointAtParam b 1)) 1e-4)
    ); same-X condition
  ); cond
); if
That won't do anything to one if it's diagonal.  IF you can assume that they will always be either horizontal or vertical [never diagonal], it could be simplified/shortened with an (if) function instead of (cond), inside one  (addprop) function.
Kent Cooper, AIA
YES!!
Thank you sir!  No diagonal lines will ever be involved here, so your answer is picture perfect Smiley Happy
Kent1Cooper
@Anonymous wrote:
.... No diagonal lines will ever be involved ….
Then this should do it:
  (addprop b
    (if (equal (car (vlax-curve-getStartPoint b)) (car (vlax-curve-getPointAtParam b 1)) 1e-4)
      "HILMOT-CONV-BLK-FRAMES" ; then [same X]
      "HILMOT-CONV-BLK-ROLLERS" ; else [same Y]
    ); if
  ); addprop
); if
Kent Cooper, AIA
