looking to add color changing to this macro
venturini.anthony
venturini.anthony
I'm looking to add another option to this macro. currently this macro reads the transparency of the corresponding excel file. I want to change layer colors too. how would i add that to this existing macro?
^C^C^P(LayersFromFile (strcat "FADE-" (cadr (assoc (progn (initget "Site Grading Drainage Utility Landscape lIghting erOsion Vehicle") (getkword "What plan are you working in? [Site/Grading/Drainage/Utility/Landscape/lIghting/erOsion/Vehicle]: ")) '(("Site" "Site") ("Grading" "Grade") ("Drainage" "Drain") ("Utility" "Util") ("Landscape" "Land") ("lIghting" "Light") ("erOsion" "Soil") ("Vehicle" "Vehicle")))) ".xlsx") "transparency")
ВeekeeCZ
That has to be done in the LayersFromFile routine which you did not post it.
venturini.anthony
THERE IS NO ROUTINE FOR THAT. I JUST LOOKS FOR THE FILE, READS THE COLUM STATED, AND CHANES THE LAYER BASED ON THE NAME. IF I WERE TO CHANGE THE "TRANSPARENCY" TO "COLOR" IN THE MACRO IT WOULD READ THE RIGHT COLUMN BUT I WANT TO CHANGE BOTH THE TRANSPARENCLY AND COLOR
paullimapa
@ВeekeeCZ is correct, LayersFromFile is a lisp function with two arguments:
#1 = name of excel file
#2 = column name
For example:
(LayersFromFile (strcat "FADE-Grade" ".xlsx") "transparency")
So if you want to add another column that changes like the Color value, then you'll need to change the LayersFromFile.lsp code to accommodate
Paul Li
IT Specialist
@The Office
