Looking for procedure to build new command
townest
townest
I'm looking for procedure to build a new command.
Specs:
Base command: Boundary
New Name: Tbound (not critical)
Functionality:  Fires 'Boundary' command; sets layer to 'bound1'; sets linetype to bylayer; sets color to bylayer; sets lineweight to bylayer; unchecks island detection; sets object type to polyline; sets boundary set to current viewpoint; upon exit reverts back to previous current layer and settings.
Let me know if you can help.
Thank you.
Tyler
Shneuph
Would you like fries with that?
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
pbejse
-setvar [ CECOLOR CELTYPE CELWEIGHT ]
Fires 'Boundary' command,  unchecks island detection; sets object type to polyline; sets boundary set to
-BOUNDARY (Command)
Object Type
-entlast Detect last entity created, assign to variable
-entmod to change layer
add 5cents and you can upsize your fries
HTH
ВeekeeCZ
Well, since the reliability of the BOUNDARY/HATCH command is as it is, especially in heavy drawings, I would suggest you to remember well all the variables it's changing. Because one day you might find yourself resetting them manually.
(defun c:Tbound (/ *error* lay col clt clw hpb idm)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if lay (setvar 'clayer lay))
    (if col (setvar 'cecolor col))
    (if clt (setvar 'celtype clt))
    (if clw (setvar 'celweight clw))
    (if hpb (setvar 'hpbound hpb))
    (if idm (setvar 'hpislanddetectionmode idm))
    (princ)
  (setq lay (getvar 'clayer))			(command "_.LAYER" "_T" "bound1" "_M" "bound1" "")
  (setq col (getvar 'cecolor))			(setvar 'cecolor "BYLAYER")
  (setq clt (getvar 'celtype))			(setvar 'celtype "BYLAYER")
  (setq clw (getvar 'celweight))		(setvar 'celweight -1)
  (setq hpb (getvar 'hpbound))			(setvar 'hpbound 1)
  (setq idm (getvar 'hpislanddetectionmode))	(setvar 'hpislanddetectionmode 0)
  (command-s "_.-BOUNDARY")
  (*error* "end")
townest
Thank you.  I'll study this and give it a go.
Tyler
