looking for documentation about 3D DWF export
Michiel.Valcke
Advisor Advisor
Message 1 of 14
Michiel.Valcke
Hi everyone,
I'm working on a proof of concept to use a reactor that will export a 3D DWF with each document save. However I can't seem to get the (command "_3DDWF" ...) part to work.
The only documentation I have found about exporting to 3D DWF is done in .NET.
Do any of you have experience with the export to 3D DWF done from autolisp/visual lisp? Or is it flat out impossible?
Replies (13)
Message 2 of 14
Moshe-A
@Michiel.Valcke  hi
Does this works
(Command "._3ddwf")
Message 3 of 14
pendean
Community Legend
Community Legend
(Command "._3ddwf") works fine here as does (Command "_3ddwf") and (Command "3ddwf").
Perhaps the issue is whatever those ...... you have partially typed that are the problem you see?
Message 4 of 14
Michiel.Valcke
I'm sorry I wasn't clear. The (command "3DDWF") or other options work, but I cannot avoid the file dialog apparently. So I was looking to see if there were other ways.
The routine would have to run silently without requiring user input. and apparently 3ddwf doesn't follow filedia.
Message 5 of 14
Kent1Cooper
[EDIT:  We "crossed in the mail," so this is a little redundant with the preceding Message, but anyway....]
Yes, those (command) functions work to invoke the command, but it brings up the file dialog box.  I assume [@Michiel.Valcke confirm?] that a reactor to do this with every Save is going to want the file name and location automated, so the User doesn't need to do anything -- just Save and the 3DDWF is handled behind the scenes.  Unfortunately, it appears that 3DDWF does not have a command-line-only no-dialog-box version into which a routine could feed a file path and name for you, even with FILEDIA set to 0.
Kent Cooper, AIA
Message 6 of 14
pendean
Community Legend
Community Legend
@Michiel.Valcke wrote:
...but I cannot avoid the file dialog apparently....
Since both FILEDIA and CMDDIA have no affect on that behavior, my guess is this is not possible.
Message 7 of 14
DGCSCAD
How about:
(command "-export")
AutoCad 2018 (full)
Win 11 Pro
Message 8 of 14
Michiel.Valcke
@DGCSCAD
The (command "-export" ) only works for 2D dwf's I believe.
Message 9 of 14
DGCSCAD
@DGCSCAD
That appears to be true. Swing and a miss. 🙂
AutoCad 2018 (full)
Win 11 Pro
Message 10 of 14
Moshe-A
@Michiel.Valcke hi,
Seems @DGCSCAD  was right EXPORT is the command to go with 😀
Message 11 of 14
DGCSCAD
-Export only publishes sheets.
The command prompt version of EXPORTDWF, EXPORTDWFX, and EXPORTPDF provides an interface for publishing drawing sheets that can be controlled by a script.
AutoCad 2018 (full)
Win 11 Pro
Message 12 of 14
paullimapa
@Michiel.Valcke if dwfX = 3ddwfs then the command line -Export version does support this option:
Paul Li
IT Specialist
@The Office
Message 13 of 14
DGCSCAD
Export, and -Export are 2 different commands. It's not the command-line version, as one would think it would be.
Export
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-A72DB257-3410-4792-B548-6B9FC1DED72B
-Export
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-EC98464B-D222-4673-BBE1-AF4B20EBF150
AutoCad 2018 (full)
Win 11 Pro
Message 14 of 14
Michiel.Valcke
I tried a version this morning with the VBA document.export method but that also didn't work. So I presume I will have to look at .NET for this kind of thing.
Thank you all for your input.
