Looking for a way to mimic Revit's align tool to align a line to another line
Haider_of_Sweden
Message 1 of 25
Haider_of_Sweden
I work with AutoCAD and Revit on a daily basis.
Often, I miss the the ability to align lines to each other in AutoCAD as you do in Revit.
If we take this situation for example:
In revit you'd go AL (the tool command= then pick what to align to, and then what to align. It would move to the place and have the same orientation too.
Is there any LISP solution for that?
Replies (24)
Message 21 of 25
john.uhden
@Sea-Haven
I thought he said he wanted to realign a LINE.  I didn't infer that he wanted to shift an entire polyline.
So, maybe his objective is to move a polyline from a vertex perpendicular to a polyline segment?  That's easy enough, but understanding what he wants is not.
John F. Uhden
Message 22 of 25
Sea-Haven
John has questions so do I, can you post a before / after so confirm what is to be done. For me need the dwg objects that did not work to look at.
I understand X Y will think about it.
Message 23 of 25
john.uhden
@Haider_of_Sweden
@Sea-Haven
Try this.  It will now realign a polyline segment as well.
Also notice the included failures.  But I don't give up so easy.
(defun c:Realign ( / *error* cmd e1 e2 ent1 ent2 etype p obj param p1 p2 p3 p4 p3a p4a ang)
   (gc)
   (vl-load-com)
   (prompt "\nREALIGN v1.1 (c)2021, John F. Uhden for @Haider_of_Sweden")
   ;; Program realigns a line or straight polyline segment
   ;; with a source line or straight polyline segment.
   (defun *error* (err)
      (if (= (type cmd) 'INT)(setvar "cmdecho" cmd))
      (vla-endundomark *doc*)
      (cond
        ((not err))
        ((wcmatch (strcase err) "*CANCEL*,*QUIT*")
          (vl-exit-with-error "\r                                              ")
        (1 (vl-exit-with-error (strcat "\r*ERROR*: " err)))
      (princ)
   ;; Initialize some drawing and program variables:
   (setq *doc* (vlax-get (vlax-get-acad-object) 'Activedocument)
         cmd (getvar "cmdecho")
   (vla-startundomark *doc*)
   (setvar "cmdecho" 0)
   (command "_.expert" (getvar "expert")) ;; dummy command
   (defun @2d (p)(list (car p)(cadr p)))
   ;; Homemade function to substitute one point in a list of points
   ;; because the AutoLisp subst function fails if the input value doesn't exactly match
   ;; any item in the list.  This substitutes by the position, not the value.
   (defun @subst_nth (new pos items / part1 part2)
     (setq part1 (reverse (cdr (member (nth pos items)(reverse items))))
           part2 (cdr (member (nth pos items) items))
     (append part1 (list new) part2)
   ;; Begin the action:
   (and
    (setq p (entsel "\nSelect source line segment: "))
    (setq e1 (car p))
	(setq ent1 (entget e1))
	(setq etype (cdr (assoc 0 ent1)))
	(cond
	  ((= etype "LINE")
    	(setq p1 (cdr (assoc 10 ent1))
	          p2 (cdr (assoc 11 ent1))
	  ((= etype "LWPOLYLINE")
	    (setq p (cadr p)
		      obj (vlax-ename->vla-object e1)
        	  p (vlax-curve-getclosestpointto obj p)
			  param (vlax-curve-getparamatpoint obj p)
		(if (not (zerop (vla-getbulge obj param)))
		  (prompt "\n  Segment selected is bulged.")
		  (setq p1 (vlax-curve-getpointatparam obj (fix param))
			    p2 (vlax-curve-getpointatparam obj (1+ (fix param)))
	  (1 (prompt (strcat "\n  Entity selected is a(n) " etype)))
	(setq p(entsel "\nSelect line segment to realign to source: "))
	(setq e2 (car p) p (cadr p))
	(or (not (equal e1 e2))
	  (prompt "\n  Same entity selected.")
	(setq ent2 (entget e2)
          etype (cdr (assoc 0 ent2))
		  obj (vlax-ename->vla-object e2)
	(cond
	  ((= etype "LINE")
        (setq p3 (cdr (assoc 10 ent2))
    	      p4 (cdr (assoc 11 ent2))
	    (setq p (vlax-curve-getclosestpointto e2 p)
		      param (vlax-curve-getparamatpoint e2 p)
			  p3 (vlax-curve-getpointatparam e2 (fix param))
			  p4 (vlax-curve-getpointatparam e2 (1+ (fix param)))
			  plist (vl-remove-if-not '(lambda (x)(= (car x) 10)) ent2)
			  ok 0
		(or
		   (prompt "\n  Segment is bulged.")
	  (1 (prompt "\n  Rntity selected is not a line or LWPolyline segment."))
	(setq ok 1)
	(setq ang (+ (angle p1 p2)(* pi 0.5)))
	(setq ok 2)
	(setq p3a (inters p3 (polar p3 ang 10) p1 p2 nil)
	      p4a (inters p4 (polar p4 ang 10) p1 p2 nil)
		  ok 3
	(if (= etype "LINE")
      (setq ent2 (subst (cons 10 p3a)(assoc 10 ent2) ent2)
	        ent2 (subst (cons 11 p4a)(assoc 11 ent2) ent2)
			ok 4
	  (progn ;; For LWPolylines
	  ;| This didn't work
	    (setq ent2 (subst (cons 10 (@2d p3a))(cons 10 p3) ent2)
	          ent2 (subst (cons 10 (@2d p4a))(cons 10 p4) ent2)
	    		ok 5
	  ;| Neither did this
        (vlax-invoke obj 'removevertex obj (fix param))
		(vlax-invoke obj 'addvertex obj (fix param) p3a)
		(vlax-invoke obj 'removevertex obj (1+ (fix param)))
		(vlax-invoke obj 'addvertex obj (1+ (fix param)) p4a)
		(setq ok 5)
	  ;| Subst isn't working here either
	    (print (mapcar 'cdr plist))
	    (setq plist (mapcar 'cdr plist)
		      plist (subst (@2d p3a) p3 plist)
		      plist (subst (@2d p4a) p4 plist)
		(print plist)
		(vlax-put obj 'coordinates (apply 'append plist))
		(vla-update obj)
		(setq ok 5)
	  ;; THIS DOES WORK!!
		      plist (@subst_nth (@2d p3a) (fix param) plist)
		      plist (@subst_nth (@2d p4a) (1+ (fix param)) plist)
		(print plist)
		(vla-update obj)
		(setq ok 5)
	(setq ok 6)
	;(print ent2)
	;(entmod ent2)
	;(setq ok 7)
	;(entupd e2)
  (*error* nil)
John F. Uhden
Message 24 of 25
aaron_gonzalez
could you modify the lisp for aling several pline with the source?, please
Message 25 of 25
aaron_gonzalez
a little modification to do iterative aling segments with the same segment source, only works with pline
   (gc)
   (vl-load-com)
      (cond
        ((not err))
      (princ)
   (defun @Anonymous (p)(list (car p)(cadr p)))
   (and
    (setq e1 (car p))
      (cond
        ((= etype "LINE")
          (setq p (cadr p)
      (while (setq p(entsel "\nSelect line segment to realign to source: "))
      (cond
        ((= etype "LINE")
                    ok 0
            (or
      (setq ok 1)
      (setq ok 2)
              ok 3
                  ok 4
        ;| This didn't work
                  ok 5
        ;| Neither did this
            (setq ok 5)
            (print plist)
            (vla-update obj)
            (setq ok 5)
        ;; THIS DOES WORK!!
            (print plist)
            (vla-update obj)
            (setq ok 5)
      (setq ok 6))
      ;(print ent2)
      ;(entmod ent2)
      ;(setq ok 7)
      ;(entupd e2)
  (*error* nil)
