Looking for a LISP routine that selects all dimensions, puts them on a particular layer, applies drawing background mask, and brings them to draw order - front.
winstonfoxnelson
winstonfoxnelson
Hello, I'm looking for a LISP routine that:
Selects all dimensions
Puts them on a particular layer
Applies a background mask  - drawing to them
Brings them to draw order - front
Thank you!
3wood
You can try the codes below.
It unlocks all layers before changing the dimension layer.
It only works on the current layout. You can modify it to make it go through all layouts.
(defun C:ADB (/ t1 s1 n1 g1 g1)
  (setq t1 (getstring T "Dimension layer name: "))
  (command "._-layer" "m" t1 "")
  (command "._-layer" "U" "*" "")
 (setq s1 (ssget "x" '((0 . "*dim*")))
       n1 0)
  (command "._draworder" "p" "" "f" )
  (repeat (sslength s1)
    (setq e1 (ssname s1 n1))
    (setq g1 (entget e1))
    (entmod (subst (cons 8 t1) (assoc 8 g1) g1))
    (setpropertyvalue e1 "Dimtfill" 1)
    (setq n1 (1+ n1))
  (command "._layerp")
  (princ)
winstonfoxnelson
Wow thanks a lot, question - I should have specified that I'd like the routine to put the dimensions on a particular layer, not prompt the user to choose the layer every time. In my case I'd like that layer to be "F-DIM-F". Could this be tweaked to do that?
3wood
Sure. Please try updated codes below:
  ;(setq t1 (getstring T "Dimension layer name: "))
  (if (setq n1 0
    (progn
      (setq t1 "F-DIM-F")
	(setq n1 (1+ n1))
  (princ)
winstonfoxnelson
Beautiful, but I have one last request...
Can you tweak it to select only those dimensions which are currently visible?
I don't know who you are or why you're helping me, but please DM me with your Paypal or Venmo and I'll show my appreciation, whether or not you can fulfill this last bit.
Thank you ever so much!
3wood
If you want to apply changes to selected dimensions only, please try the codes below.
  (if (setq n1 0
	    s1 (ssget '((0 . "*dim*")))
    (progn
      (setq t1 "F-DIM-F")
	(setq n1 (1+ n1))
  (princ)
