Load .vlx in autocad startup
Angelswing91
Angelswing91
Hi all,
It seems i have a problem... in my autocad map 3D not working Appload (i think it was disabled), all my LISP files loaded in CUI, but there i can load only lisp files.
I have few .vlx files from internet, so i can't load it. I found a way create a lisp, in the same location (command "load" "addv.vlx"), but for for all .vlx and i don't know why...
Any suggestions how i can fix it, or anybody knows more options to load .vlx on startup?
CodeDing
@Angelswing91 ,
Here's the method I recommend.
Open your acaddoc.lsp file (this will help you open it).
(startapp "notepad" (findfile "acaddoc.lsp"))
Then, add your .vlx files to be loaded within your acaddoc.lsp file.
(load "MyFile.vlx" "\nThere was an error loading MyFile.")
Now, these .vlx files will be loaded every time you open a drawing automatically.
Best,
~DD
Sea-Haven
have you tried Appload and add the vlx to the "start up suite"
vladimir_michl
It is not (command "load" file... but just (load file...
Also the APPLOAD cannot be easily "disabled" - try ._APPLOAD and just drag the VLX file to its briefcase icon.
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
pbejse
@Angelswing91 wrote:
I have few .vlx files from internet, so i can't load it...
Does it say Unable to load addv.VLX file? or nothing at all? if its the former, one time or another the user selected "Do Not Load" when give the security warning AND secureload system variable is 1.
Turn SECURELOAD to 0 OR re-compile the VLX file and click Always load upon apploading.
HTH
