LISTFUNS
LISTFUNS
john.uhden
Mentor Mentor
LISTFUNS
john.uhden
For those who have trouble finding or remembering what functions and variables have been defined, here is something I still use.
I have never published it.  It's not al all complicated, but it's free.
(defun C:LISTFUNS ( / *error* vars str vtype ans mode item items)
   ;*         LISTFUNS.LSP  by  John F. Uhden                                   *
   ;*                           2 Village Road                                  *
   ;*                           Sea Girt, NJ  08750                             *
   ; v2.2 (10-10-00) added (wcmatch) search for both input and (strcase) of input
   ; v15.00 (04-07-00) for R15
   ; v15.01 (11-05-01) finally added choices for pageTb saFearray vAriant Vla-Object
   ; v15.01F (01-04-17) removed security for release as freeware to AutoCAD forum.
   ;; Function lists all atoms in the (atoms-family) via wildcard match,
   ;; and let's you restrict the search to atoms of certain types.
   (gc)
   (prompt "\nLISTFUNS v15.01F (c)1994-2016, John F. Uhden")
   (setq items (atoms-family 1)) ; set list before this program adds any items, er atoms.
   (defun *error* (err)
      (if (= (type fp) 'FILE)(setq fp (close fp)))
      (mapcar '(lambda (x)(setvar (car x)(cdr x))) vars)
      (vla-endundomark *doc*)
      (if (wcmatch (strcase err) "*CANCEL*,*QUIT*")
         (vl-exit-with-error "\r                                              ")
         (vl-exit-with-error (strcat "\r*ERROR*: " err))
  (or *acad* (setq *acad* (vlax-get-acad-object)))
  (or *doc* (setq *doc* (vla-get-ActiveDocument *acad*)))
  (vla-startundomark *doc*)
  ;; Kent Cooper's method is much cleaner, but I am not Kent Cooper, just a fan.
  (setq vars (mapcar '(lambda (x)(cons x (getvar x))) '("cmdecho")))
  (mapcar '(lambda (x)(setvar (car x) 0))  vars)
  (command "_.expert" (getvar "expert")) ;; dummy command
   (if (/= (type $cv_lf_str) 'STR)(setq $cv_lf_str "*"))
   (if (/= (type $cv_lf_file) 'STR)(setq $cv_lf_file "LISTFUNS.TXT"))
   (if (/= (setq str (getstring (strcat "\nFunction name(s)/<" $cv_lf_str ">: "))) "")
      (setq $cv_lf_str str)
   (if (not (vl-position $cv_lf_vtype '("Exsubr" "eXrxsubr" "File" "Int" "List" "eName" "paGetb" "Pickset" "Real" "Safearray" "sTr" "sUbr" "sYm" "vAriant" "Vla-object" "*")))
      (setq $cv_lf_vtype "*")
   (initget "Exsubr eXrxsubr File Int List eName paGetb Pickset Real Safearray sTr sUbr sYm vAriant Vla-object *")
   (setq ans (getkword (strcat "\nVariable Type...\n Exsubr/eXrxsubr/File/Int/List/eName/paGetb/Pickset/Real/Safearray/sTr/sUbr/sYm/vAriant/Vla-object/*, <" $cv_lf_vtype ">:")))
   (if ans (setq $cv_lf_vtype ans))
   (initget "Append Overwrite No")
   (setq ans (getkword "\nWrite to file?  Append/Overwrite/<No>: "))
   (cond
      ((= ans "Append")(setq mode "a"))
      ((= ans "Overwrite")(setq mode "w"))
      (1 (setq mode nil))
   (if (and mode (setq ans (getfiled "Enter File Name" $cv_lf_file "" 5)))
      (setq $cv_lf_file ans
            fp (open $cv_lf_file mode)
      (setq fp nil)
   (foreach item items
      (if (and item (wcmatch item (strcat $cv_lf_str "," (strcase $cv_lf_str)))
          (or (= $cv_lf_vtype "*")(= (type (eval (read item))) (read $cv_lf_vtype))))
         (if fp
            (progn
               (princ (strcat "\n" item "\t") fp)
               (prin1 (eval (read item)) fp)
            (progn
               (princ (strcat "\n" item "\t"))
               (prin1 (eval (read item)))
   (*error* nil)
(defun c:LF ()(c:listfuns))
John F. Uhden
john.uhden
Thanks, John.
John F. Uhden
