List transformation
List transformation
Browning_Zed
List transformation
Browning_Zed
Hi all.
I need help changing the list. The original list has the following format:
'((2.1 3.5 0.0) (10.9 11.2 3.6) (12.4 19.7 5.5))
it needs to be converted to a list of this format:
'(2.1 3.5 10.9 11.2 12.4 19.7)
that is, in the original list should remove the third item of each sublist, and transform the original list from a nested list to a simple list. In other words, the elements of the original list marked in red must be deleted.
hak_vz
(defun take (amount lst / ret)(repeat amount (setq ret (cons (car lst) (take (1- amount) (cdr lst))))))
(defun take2 (lst) (take 2 lst))
(apply 'append(mapcar 'take2 '((2.1 3.5 0.0) (10.9 11.2 3.6) (12.4 19.7 5.5))))
@Browning_Zed
I guess you've received this functions before. It's time to start using them.
Miljenko Hatlak
-didier-
Bonjour @Browning_Zed
Here is my proposal to do this task
Amicalement
(apply 'append (mapcar (function (lambda (x) (reverse (cdr (reverse x))))) l1))
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Browning_Zed
Thanks for the help. What function are we talking about?
Browning_Zed
Thank you very much.
hak_vz
Function take, I use it regularly in my codes, and variations with apply mapcar.
Miljenko Hatlak
Browning_Zed
Got it, thanks.
