List manipulation
List manipulation
GeryKnee
List manipulation
GeryKnee
There are errors here
(defun LM:SubstNth ( a n l );;Lee Mac,Copyright © 2011
(if l
(if (zerop n)
(cons a (cdr l))
(cons (car l) (LM:SubstNth a (1- n) (cdr l)))
(defun fnPrinNumListValues(aNumList / count Num)
(if aNumList
(progn
(setq count 0)
(repeat (sslength aNumList)
(setq Num (nth count aNumList))
(princ (strcat "\n" (vla-get-textString count) (vla-get-textString Num)))
(setq count (1+ count))
) ; repeat
);;progn
(princ "\nNo Num List");; else
);;if
(princ)
(defun c:xx()
(princ)
(setq ExIDList (list 0 0 0 0 0 0 0))
(fnPrinNumListValues ExIDList)
;;(xW (vl-list-length ExIDList))
;;Change 3rd item
;;(LM:SubstNth 1 3 ExIDList)
(princ)
Kent1Cooper
That is never enough information.
Kent Cooper, AIA
Moshe-A
@GeryKnee ,
 true, what's that?
the argument of (vla-get-textString) is VLA-OBJECT
what type Count and Num ???
the following fix is working 😀
note the use of (foreach) here.
Moshe
(defun c:xx()
(princ)
;;Change 3rd item
(princ)
(defun LM:SubstNth (a n l );;Lee Mac,Copyright © 2011
 (if l
  (if (zerop n)
   (cons a (cdr l))
(defun fnPrinNumListValues( aNumList / count Num)
 (if (null aNumList)
  (progn ; else
   (setq count 0)
   (foreach Num aNumList
    (princ (strcat "\n" (itoa count) " " (itoa Num)))
   ); foreach
  ); progn
 ); if
;| (if aNumList
  (progn
   (setq count 0)
   ); repeat
  ); progn
 ); if |;
(defun c:xx (/ ExIDLIst)
 ; Change 3rd item
 (terpri)
 (setq ExIDList (LM:SubstNth 1 3 ExIDList))
 ; (setq ExIDList (list 0 0 0 0 0 0 0))
 (princ)
