Lisps to calculate total area of only Hatches/ of Hatches AND other Objects
Hello everybody,
last time I needed to calculate total area of some objects. I found Lee Mac's "TAREA" lisp here:
http://www.lee-mac.com/totallengthandarea.html
I
t is great!
But, it doesn't work for Hatch Patterns.
I wanted to have two additional lisps:
1. Lisp which calculates cumulative (total) area of selected objects, which are ONLY Hatches
2. Lisp which calculates cumulative (total) area of selected objects, which are  Polylines, Circles, etc. AND Hatches
The lisp number 1. I called TAREAH, and The lisp number 2. I called TAREADW.
So I modified your TAREA lisp and I got two new lisps which I wanted, that means "TAREAH" and "TAREADW".
Here are thtse lisps:
"TAREADW"
;;---------------------=={ Total Area }==---------------------;; ;; ;; ;; Displays the total area of selected objects at the ;; ;; command line. The precision of the printed result is ;; ;; dependent on the setting of the LUPREC system variable. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2013 - www.lee-mac.com ;; ;;------------------------------------------------------------;; (defun c:tareaDW ( / a i s ) (if (setq s (ssget '( (0 . "CIRCLE,ELLIPSE,*POLYLINE,SPLINE,HATCH") ; "HATCH" - Addad by DW (-4 . "<NOT") (-4 . "<AND") (0 . "POLYLINE") (-4 . "&") (70 . 80) (-4 . "AND>") (-4 . "NOT>") ) ) ) (progn (setq a 0.0) (repeat (setq i (sslength s)) (setq a (+ a (vlax-curve-getarea (ssname s (setq i (1- i)))))) ) (princ "\nTotal Area: ") (princ (rtos a 2)) ) ) (princ) ) (vl-load-com) (princ)
"TAREAH"
; http://www.lee-mac.com/totallengthandarea.html
(defun c:tareaH ( / a i s )
    (if (setq s
            (ssget
               '(   0 . "HATCH"
        (progn
            (setq a 0.0)
            (princ (rtos a 2))
    (princ)
Please, if you could, tell me what I made wrong and why they don't work properly.
ВeekeeCZ
The reason is used function (vlax-curve-getarea en). As you can see is for CURVEs only.
Thank you very much.
Do anybody knows how to edit this lisp to get its right version?
