Lisps are not loaded HELP!
Message 1 of 10
I have problem of loading my lisps automatically for all my documents:
I put all my desired lisps in this folder:
C:\Program Files\Autodesk\AutoCAD 2018\Support\en-us
also I add these lines to my  ACAD2018DOC.LSP (there are more but for example) :
(load "3PRD")
(load "atc")
(load "b1")
(load "bi")
In autocad I made custom toolbar and loaded the lisp :
(for example)  for "3prd.lsp"  I wrote in the Macro line :
^C^C_3PRD;
In other versions of autocad it works fine , but I have tried in on Autocad 2018 and it didn't work.
Also every time I open my Autocad  my toolbars is messy (here is a picture):
https://drive.google.com/open?id=0BywYPAsctPuLdFpqNmNfMVVTZFU
Any help would be greatfull.
Thank you
Eyal
Replies (9)
Message 2 of 10
Perhaps this works:
^C^C^P(if (= C:3PRD nil)(load"3PRD")(princ))^P _3PRD
Message 3 of 10
It doesn't work.
The problem seems to be with loading the lisps when the document is loading.
I put the lisps in this path:
is it ok for Autocad 2018?
Also in acad2018doc.lsp I put the line:
for example to load the lisp : linebetween.lsp
(load "LineBetween")
What's the problem?
When I load the lisp within Autocad regularly it works fine.
Please I need your help.
Message 4 of 10
cadffm
Use a S::STARTUP function for load your Lisp, works?
http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-FDB4038D-1620-4A56-8824-D37729D42520
Note: Acad20xxdoc.lsp is a Systemfile, For own gaming use ACADDOC.lsp
Sebastian
Message 5 of 10
It doesn't work for me. I installed the update of 2018 and still the lisps are not loaded maybe I need to put them in another directory and not in:
C:\Program Files\Autodesk\AutoCAD 2018\Support\en-us.
In the acadoc.lsp I put the lines:
for example:
(load "LINE_DIV")
(load "ObjectBreakV1-0")
whats wrong?
regards.
Message 6 of 10
ВeekeeCZ
It's acaddoc.lsp
make sure that the file path of your lisp files is one of your support path... and also check the security setting. See HERE and help.
Good luck.
Message 7 of 10
Ranjit_Singh
You need to put them in one of the support file search paths; one of these
(getenv "Path")
If C:\Program Files\Autodesk\AutoCAD 2018\Support\en-us isn't part of the path variable then add it to the support path via options -> filesSupportPath.png
Message 8 of 10
Kent1Cooper
@ВeekeeCZ wrote:
It's acaddoc.lsp
Absolutely.  Help specifically warns against modifying the ACAD<release-number>.lsp file, and makes no mention whatever of any ACAD<release-number>DOC.lsp file.  The one that it looks for, and loads in every drawing if it's present in a folder in the Support File Search Path list, is under the name ACADDOC.lsp.  Also, make sure you don't have more than one such file in different folders in the list -- if you do, I believe it will run what's in the first one it finds, and ignore any others, so if anything you want done is spelled out but in another ACADDOC.lsp file, it won't be done.
Kent Cooper, AIA
Message 9 of 10
Ranjit_Singh
@Kent1Cooper wrote:
no mention whatever of any ACAD<release-number>DOC.lsp file.............
I believe with AutoCAD 2017 they have started the acad<release-number>doc.lsp. See help from AutoCAD for AutoCAD 2017. However, they do warn not to change its contents. So OPs best bet is to add to acaddoc.lsp and/or acad.lsp
EDIT: I did find this AutoCAD help which even mentions of acad2000doc.lsp So, I guess it has existed forever, maybe/maybe not in R14.
Message 10 of 10
Kent1Cooper
@Ranjit_Singh wrote:
I believe with AutoCAD 2017 they have started the acad<release-number>doc.lsp. See help from AutoCAD for AutoCAD 2017. However, they do warn not to change its contents. ....
I was looking in just-plain Help, not the Knowledge Network.  There's no mention of it in the area about automatically loading stuff, where it talks about ACAD.lsp and ACADDOC.lsp.
In any case, it does say, in your linked Knowledge Network article:
Note: Do not modify the reserved acad<release>doc.lsp file. Autodesk provides the acad<release>doc.lsp file, which contains required, release-specific, AutoLISP-defined functions.
Kent Cooper, AIA
