it's init_d_values that comes common for drawers codes. i changed it in last code to init_dn_values. do check them work in pair.
(defun c:place_drawers_no_front (/ interior_h_line_1 redraw_ interior_h_line_2 line_ends min_x max_x min_y max_y unit_interior_depth unit_interior_height
drawer_ledge drawer_ledge_gap drawer_runner_increment drawers_number drawer_set_back drawer_height
drawer_runner_calculated drawer_runner drawer_block index
(redraw)
(defun get_dyn_property_by_name (dyn_property_name insert_object / dyn_property_found)
(if (vl-some '(lambda (dyn_property) (= dyn_property_name (vla-get-propertyname (setq dyn_property_found dyn_property))))
(vlax-invoke insert_object 'getdynamicblockproperties)
) dyn_property_found nil
(setq init_dn_values (if (null init_dn_values) (setq init_dn_values '(3 70 40)) init_dn_values)
interior_h_line_1 (car (entsel "\nPick unit interior horizontal 1st line: "))
redraw_ (redraw interior_h_line_1 3)
interior_h_line_2 (car (entsel "\nPick unit interior horizontal 2nd line: "))
redraw_ (redraw interior_h_line_2 3)
line_ends (apply 'append (mapcar '(lambda (line) (list (vlax-get (vlax-ename->vla-object line) 'startpoint)
(vlax-get (vlax-ename->vla-object line) 'endpoint)
(list interior_h_line_1 interior_h_line_2)
min_x (apply 'min (mapcar 'car line_ends))
max_x (apply 'max (mapcar 'car line_ends))
min_y (apply 'min (mapcar 'cadr line_ends))
max_y (apply 'max (mapcar 'cadr line_ends))
unit_interior_depth (- max_x min_x)
unit_interior_height (- max_y min_y)
drawer_ledge 15
drawer_ledge_gap 5
drawer_runner_increment 20
drawers_number (getint (strcat "\nEnter number of drawers <" (itoa (nth 0 init_dn_values)) ">: "))
drawers_number (if (null drawers_number) (nth 0 init_dn_values) drawers_number)
drawer_set_back (getint (strcat "\nEnter drawer set back <" (itoa (nth 1 init_dn_values)) ">: "))
drawer_set_back (if (null drawer_set_back) (nth 1 init_dn_values) drawer_set_back)
drawer_gap (getint (strcat "\nEnter drawer gap <" (itoa (nth 2 init_dn_values)) ">: "))
drawer_gap (if (null drawer_gap) (nth 2 init_dn_values) drawer_gap)
drawer_height (/ (- unit_interior_height (+ drawer_ledge_gap (* drawers_number (+ drawer_ledge drawer_gap)))) drawers_number)
drawer_runner_calculated (* drawer_runner_increment (fix (/ (- unit_interior_depth drawer_set_back drawer_runner_increment) drawer_runner_increment)))
drawer_runner (getint (strcat "\nEnter drawer runner <" (itoa drawer_runner_calculated) ">: ")) ; Drawer Runner
drawer_runner (if (null drawer_runner) drawer_runner_calculated drawer_runner)
drawer_block (vla-insertblock (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
(vlax-3d-point (setq 1st_insert_point (list (- max_x drawer_set_back) (+ min_y drawer_ledge_gap drawer_ledge))))
"Drawer Side No Front"
1 1 1 0
index 0
(vlax-put (get_dyn_property_by_name "Height" drawer_block) 'value drawer_height)
(vlax-put (get_dyn_property_by_name "Runner" drawer_block) 'value (float drawer_runner))
(repeat (1- drawers_number)
(vla-move (vla-copy drawer_block)
(vlax-3d-point 1st_insert_point)
(vlax-3d-point (list (car 1st_insert_point) (+ (cadr 1st_insert_point) (* (1+ index) (+ drawer_height drawer_gap drawer_ledge)))))
(setq index (1+ index))
(setq init_dn_values (list drawers_number drawer_set_back drawer_gap))
(redraw interior_h_line_1 4)
(redraw interior_h_line_2 4)
(princ)
