Lisp works in one drawing but not in other - what gives?!
Buzz0m
Buzz0m
So I found a lisp that controls the decimal places of numeric values that are given as text objects.
The lisp works in certain drawings but not all. The "problematic" drawings show the objects as "text" -objects and the lisp runs smoothly until end without errors.
Does anybody know if there is something in the code that is version specific or something that could explain the seemingly unreliable behavior.
(defun c:R2D2 (/ ss)
 (if (setq ss (ssget "_:L" '((0 . "TEXT"))))
   ((lambda (i / e l)
      (while (setq e (ssname ss (setq i (1+ i))))
        (setq l (entget e))
        (entmod (subst (cons 1 (rtos (atof (cdr (assoc 1 l))) (getvar 'lunits) 2)) (assoc 1 l) l))
     -1
 (princ)
https://www.cadtutor.net/forum/topic/23234-lisp-routine-that-will-round-decimal-places/
cadffm
you forgot to say or show what doesn't work,
what happens instead and also an example file is not attached.
Lunits setting is part of a DWG file, the same with dimzin (relevant for RTOS)
A sample file (DWG) would have answered all questions.
Checkout and compare the Lunits and Dimzin settings, or share a sample DWG.
Sebastian
ronjonp
Make sure DIMZIN is set to 0.
Buzz0m
Changing the Dimzin value did the trick! I guess I'll add a line or two to temporarily switch the dimzin value for the duration of the lisp!
Thanks @cadffm  and @ronjonp  for your shared knowledge! This is definitely something I would not have figured out by myself!
PS: my apologies for not sharing a dwg. I was banking on somebody seeing the problem/solution right away even though I subconsciously knew that a dwg would have made it easier.
Buzz0m
http://www.lee-mac.com/consistentrtos.html
And here is Lee-Mac's explanation about it in case somebody stumbles upon this issue and needs more clarification.
ronjonp
That's the same link I pointed to in my reply 😎
Buzz0m
Oh sorry I didn't even understand it was a link!
