Lisp with EXPORTPROPERTYDATA (AUTOCAD ARCHITECTURE)
felix.corre
felix.corre
With AUTOCAD ARCHITECTURE, my simple Lisp:
(defun c:exportprop ()
(command "EXPORTPROPERTYDATA")
(command "G")
(command "TEMP")
(command "")
A dialog box pop up for save the export(attached picture).
With my LISP is it possible to save with name "Temp.mdb" in "D:\\Test\\"?
Thanks a lot
Sea-Haven
Try this change in your code the "-" can imply run without a dialouge "-exportpropertydata"
felix.corre
Thanks, I had to think about it, unfortunately, this command does not exist.
jtm2020hyo
Is possible export data to mdb?
Sea-Haven
I dont have Architecture so can  not help any more, only know that Architure does have a VL link via a DLL to get at property data. Its not available in CIV3d etc.
felix.corre
Yes, being new to .NET, I use EXPORTPROPERTYDATA then on this list I select the object with the HANDLES and I update my property set data with the -PROPERTYDATAEDIT command. In VBA.
