LISP to Zoom Extents on Drawing Load – Paperspace Only
nrz13
Advisor Advisor
Message 1 of 27
nrz13
Does anyone already have a LISP or know how to tell AutoCAD to zoom extents on the current layout if it is a Paperspace layout?  It only needs to be the current layout when opened, since that's the only one the bug affects, but we don't want model space zoomed to extents automatically.
Since it doesn't seem that Autodesk is going to fix the bug it introduced in 2015 with the statusbar loading over the layout, I guess it's time to add a fix to my custom.lsp file.
IF LAYOUT=PAPERSPACE, THEN:
(command "zoom" "extents")(princ))
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Replies (26)
Message 21 of 27
hmsilva
You're welcome, nrz13!
Glad I could help
Henrique
Message 22 of 27
Lineabove
The zoom to extents on opening looks good, but I am not sure after reading the post what lines I should add to my acaddoc.lsp file.
Please add a post with the actual lines.
Message 23 of 27
nrz13
Lineabove:
Just add the following to your acaddoc.lsp file:
; Zoom Paperspace Layout to Extents on Drawing Load (workaround for AutoCAD 2015/2016 Bug)
(if (and (/= 1 (getvar "tilemode"))
         (= 1 (getvar "cvport"))
  (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) (strcat "_.zoom extents\r"))
Message 24 of 27
Lineabove
Thank you.
Message 25 of 27
here's one that I found some time ago that will zoom extents all layout tabs and zoom extents the model space...hope it works for you too:)
(defun C:ZA ()
  (foreach lay (layoutlist)
    (setvar 'ctab lay)
    (command "_.pspace" "_.zoom" (getvar 'limmin) (getvar 'limmax))
  ); end foreach
  (setvar 'ctab "Model")
  (command "_.mspace" "_.zoom" "extents" (getvar 'limmin) (getvar 'limmax))
); end defun
Message 26 of 27
pbejse
Message 27 of 27
🤣🤣 sorry...just came across this post thought i'd contribute for the next poor sap that comes along!!🤣
