lisp to view street views
belavyas
Message 1 of 11
belavyas
Hi all,
Is there any lisp to view street views by clicking in the DWG file.
Thanks in advance.
Bela
Replies (10)
Message 2 of 11
ВeekeeCZ
Do you mean Google Street View?
Then probably THIS tool with some info HERE could help.
Message 3 of 11
belavyas
No this tool has the same error.
Thanks.
Message 4 of 11
ВeekeeCZ
Would be nice of you if you at least link your other threads that are related to this one so we know WHAT ERROR you're talking about.
If you type this into the command-line
(command "browser" "")
do you retrieve the same error?
Message 5 of 11
belavyas
yes I do
Message 6 of 11
belavyas
giving me this notification
Message 7 of 11
ВeekeeCZ
Then your default browser file association is broken - it's a Windows issue. Something like if you double click on dwg file it won't launch AutoCAD.
Look HERE  how to fix it for Chrome, or find similar for whatever browser you use.
Message 8 of 11
DC-MWA
We use this to link objects to google maps in our drawings such as vicmaps etc.
(defun C:DO_MAP (/ Project_name link_desc street_address street_name city_name map_link ent)
(setq link_desc "Link to Google Maps")
(initget 1)
(setq street_address (getint "\nEnter street address: "))
(setq street_name (getstring T "\nEnter street or road name <name only>: "))
(setq city_name (getstring T "\nEnter city or town name: "))
(setq map_link (strcat "https://www.google.com/maps/place/" (rtos street_address 2 0) " " street_name ", " city_name ", CA"))
(setq ent (car (entsel "\nSelect Object to Add Hyperlink: ")))
(command "-hyperlink" "insert" "object" ent "" map_link "" link_desc)
(Princ (strcat "\nSelected object is now linked to: " map_link " on google maps."))
);end DO_MAP
Message 9 of 11
belavyas
Does not work. When I try to connect to user group in Help menu in Autocad it gives me the same error. Changed the default browser to Google chrome .
Need help.
Bela
Message 10 of 11
ВeekeeCZ
Check and possibly fix the Registry, look HERE
Message 11 of 11
Sea-Haven
I posted elsewhere your other post new it was easy but this is lat long. So may need civ3d.
(command "browser" "https://www.google.com.au/maps/@-33.8567844,151.213108,17z")
