LISP to use specific layers for commands
FMM_MK
Message 1 of 21
FMM_MK
Hello guys and greetings from germany,
I don't know anything about creating LISPs for AutoCAD - but I'm looking for some to change the current layer (after executing a command) to a specific one and then swicht back to the current.
I need this for the following commands:
Current layer = 0 - command "_mtext" with layer = text - switch layer back to current layer after executing the command
Current layer = 0 - command "_text" with layer = text - switch layer back to current layer after executing the command
Current layer = 0 - command "_mleader" with layer = mleader - switch layer back to current layer after executing the command
Current layer = 0 - command "_insert" with layer = block - switch layer back to current layer after executing the command
I already know how to do this with the tool palette - but I don't want to work with it, cause I'm using the toolbars.
Hope you guys can help me!
Thank you for your help in advance!
Replies (20)
Message 21 of 21
Sea-Haven
Like Kent's answer keeping it simple you could do like B1, B2, so draw a certain beam 1 on layer1, Beam2 on layer2.
The other way in more complicated code is using a simple (setvar 'clayer "Beam2") before drawing objects. So the beam has objects on different layers.
As suggested also check does layer exist. So use a small global defun.
(defun chklay (lay COL LT / )
(if (= (tblsearch "layers" lay) nil)
  (command "-layer" "M" lay "C" col "" "LT" lt "" "")
  (setvar 'clayer lay)
(princ)
(chklay "Beam2" 1 "Continuous")
