LISP to trim the first character of multiple texts
I need a Lisp that can trim the first character of multiple texts.
Please help
thank you in advance.
Kent1Cooper
If they're all Text/Mtext without any internal formatting  before the first "real" character, maybe something like this [in simplest terms, minimally tested]:
(defun C:T-1 (/ ss n tdata)
  (prompt "\nTo remove the first character from Text/Mtext,")
  (if (setq ss (ssget '((0 . "*TEXT"))))
    (repeat (setq n (sslength ss)); then
      (setq tdata (entget (ssname ss (setq n (1- n)))))
      (entmod
        (subst
          (cons 1 (substr (cdr (assoc 1 tdata)) 2)); drop first character
          (assoc 1 tdata)
          tdata
Kent Cooper, AIA
lewyee1976
mod code to trim from last char!
(defun C:TRR (/ ss n tdata)
(entmod
(subst
(cons 1 (substr (cdr (assoc 1 tdata)) 1 (-(strlen (cdr(assoc 1 tdata))) 3))) ; drop last character
(assoc 1 tdata)
tdata
Kent1Cooper
[You should also change the wording of the prompt.]
Kent Cooper, AIA
