Lisp to tell me how far along a polyline I am (chainage)
barry2104
barry2104
I have a polyline representing the middle/axis of a road, containing straights and arcs. The road/axis starts at chainage 0 and Ends at chainage 6543.21 (which equates to the length of the axis/polyline).
I want to be able to load a Lisp that lets me pick any Point along the polyline ("nearest to" snap, not just at nodes) and have the command line tell me how far along I am / what the "chainage" is at that Point.
Has anyone got (or can write) such a Lisp that would do this?
Running AutoCAD Architecture 2020, in German
DannyNL
Can you post an example drawing?
Always easier to see what needs to be done and test.
marko_ribar
Untested...
(defun c:foo ( / c p l )
  (vl-load-com)
  (while
    (or
      (not (setq c (car (entsel "\nPick curve..."))))
      (if c
        (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getstartpoint (list c)))
    (prompt "\nMissed or picked wrong entity type...")
  (initget 1)
  (setq p (getpoint "\nPick point on curve : "))
  (setq l (vlax-curve-getdistatpoint c (vlax-curve-getclosestpointto c p)))
  (prompt "\nYou picked point at distance : ") (princ (rtos l 2 50)) (prompt " from its start point of curve...")
  (princ)
Marko Ribar, d.i.a. (graduated engineer of architecture)
Kent1Cooper
In simplest terms, without verifying appropriate selection, etc., and reporting using whatever your distance Units mode and precision settings are:
(vl-load-com); [if needed]
(defun C:RCD (/ esel); = Report Chainage Distance
  (setq esel (entsel "\nSelect Polyline at desired location: "))
  (prompt
    (strcat
      "\nChainage distance at that point is "
      (rtos (vlax-curve-getDistAtPoint (car esel) (osnap (cadr esel) "_nea")))
Kent Cooper, AIA
