Lisp to Set layers
jwylie2020
Lisp to Set layers
jwylie2020
Can someone give me some insight on why the lisp code doesn't work for all layers. The lisp is below.
Example: (command "_.LAYER" "_COLOR" "253" "*P*ELECTRIC*" "") does not turn the electric layer color to 253
The *UTIL* layers do not thaw, there is a variety of layers that should thaw
 P-UTIL Sanitary UG
 P-UTIL Sanitary STR
 P-UTIL Water UG
 P-UTIL Water STR
The (command "_.LAYER" "_THAW" ",*SURF*,*CONT*" "") was part of the first layer thaw code line and did not work but when I moved it to a second line it worked?
Is there something I have wrong not giving me the best 100% results. It seems like I am at 75% expected results.
John
;TYPE SETDRAINLAYERS TO SET THE SITE LAYERS OF A PROJECT
(defun c:SETDRAINLAYERS ()
(COMMAND "UNDO" "BE")
(command "_.LAYER" "_THAW" "0","*ANNO*,*BNDY*,*ALIGN*,*UTIL*,*VIEWPORT*,*PVMT*" "")
(command "_.LAYER" "_FREEZE" "*PNT*,*BREAK*,*UG,*DEMO,*REM,*GND*SHOT*,*X*PVMT*CENTER*,*MARKING*,*X-LAND*,*P*SETBACK*,*TAP*,*|*NoPlot*" "")
(command "_.LAYER" "_COLOR" "1" "*P-BNDY*" "")
(command "_.LAYER" "_COLOR" "3" "*P*BASIN*,*P*DITCH*CENTERLINE*" "")
(command "_.LAYER" "_COLOR" "12" "*P*LOTS*" "")
(command "_.LAYER" "_COLOR" "4" "*P-ANNO*,*P*EASEMENT*" "")
(command "_.LAYER" "_COLOR" "7" "*P*STORM*CASTING*,P*SANITARY*,*P*WATER*" "")
(command "_.LAYER" "_COLOR" "41" "*NoPLOT" "")
(command "_.LAYER" "_COLOR" "136" "*P-PVMT*" "")
(command "_.LAYER" "_COLOR" "210" "*P*STORM*" "")
(command "_.LAYER" "_COLOR" "212" "*P*STORM*STR*,*STORM*SUBDRAIN*" "")
(command "_.LAYER" "_COLOR" "214" "*P*ANNO*STORM*" "")
(command "_.LAYER" "_COLOR" "230" "*P-BNDY RW*" "")
(command "_.LAYER" "_COLOR" "250" "*MASK*" "")
(command "_.LAYER" "_COLOR" "252" "*RIPRAP*,*X-ANNO*,*CONST*LIMITS*,P-GND*PAD*,*P*ANNO*LOT*" "")
(princ "\nRelayering complete")
(COMMAND "UNDO" "END")
JL
C3D 2024
Win 11 Pro
paullimapa
I see some errors with these 2 lines:
should be:
(command "_.LAYER" "_THAW" "0,*ANNO*,*BNDY*,*ALIGN*,*UTIL*,*VIEWPORT*,*PVMT*" "")
(command "_.LAYER" "_THAW" "*SURF*,*CONT*" "")
Paul Li
IT Specialist
@The Office
jwylie2020
Thanks Paul
I will update and check (early tomorrow) the rest of the code format.
John
JL
C3D 2024
Win 11 Pro
ВeekeeCZ
This simple adjustment makes in one undo record and one layer state record (layerp).
  (command "_.LAYER"
jwylie2020
Thanks, both of you.
This is simpler and can be modified for various sheets.
I do not see a layer state being created before or after an undo but, that is ok.
  (command "_.LAYER"
   "_THAW" "0,*ANNO*,*BNDY*,*ALIGN*,*UTIL*,*VIEWPORT*,*PVMT*,*SURF*,*CONT*"
   "_FREEZE" "*PNT*,*BREAK*,*DEMO,*REM,*GND*SHOT*,*X*PVMT*CENTER*,*MARKING*,*X-LAND*,*P*SETBACK*,*TAP*,*|*NoPlot*"
   "_COLOR" "253" "*P*ELECTRIC*,*LIGHT*"
JL
C3D 2024
Win 11 Pro
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
