Lisp to select dimension , divide its value by a space , round the number up, and copy it to the clipboard
the2nd_ofme
the2nd_ofme
Lisp to select dimension , divide its value by a user manually space ( Distance ) , round the number up, and copy it to the clipboard
plz
Kent1Cooper
Is "it" that is to be copied to the clipboard the rounded-up number, as text?
Kent Cooper, AIA
the2nd_ofme
thx for replying
yes it is
Kent1Cooper
In simplest terms, try this:
(defun C:DDC (/ dim div mea num)
  (setq
    dim (car (entsel "\nSelect Dimension object to report on: "))
    div (getdist "\nDivisor distance: ")
    mea (cdr (assoc 42 (entget dim)))
    num
        (fix (/ mea div))
        (if (= (rem mea div) 0) 0 1)
  (vlax-invoke
    (vlax-get
      (vlax-get (setq htmlfile (vlax-create-object "htmlfile")) 'ParentWindow)
      'ClipBoardData
    'SetData
    "Text"
    (itoa num)
That assumes rounding up to mean to the next integer value, and if it divides exactly, it doesn't jump it up by one.
It could use enhancements such as a check on the type of object selected [not just that it's a Dimension, but one of a linear nature, not angular and maybe not ordinate], and could report to the command line what it put into the clipboard, and probably some other things.
Kent Cooper, AIA
the2nd_ofme
u made my day
It took too much of my time searching about it , even I tried to learn the AutoLISP
thx a lot
