LISP to Select Blocks and Add Attributes
Kyle.para
Message 1 of 54
Kyle.para
Hi All,
We have to add a ton of attributes to all of our blocks.
I found code that was originally written by Lee Mac, but it was designed to type in the block name that you wanted.
I just want to be able to select all the blocks that I want and then have it insert the tags into all of the blocks that are selected.
I tried to change the "name enter box" to a select command but the program comes back with no blocks found.
Sorry I am new to this and may as well be trying to learn another language.
(defun c:addattribs ( / blk def )
  ; Get Entities
    (while (not blk)
            (princ "\nSelect Blocks to Update:")
               (setq blk (ssget '((-4 . "<NOT") (0 . "INSERT,POLYLINE,VIEWPORT") (-4 . "NOT>"))))
    ) ;_  end while
        (if (/= "" blk)
        (progn
            (setq def (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) blk))
            (vla-addattribute def
                (getvar 'textsize)
                acattributemodelockposition
                "New Attribute 1"
                (vlax-3D-point 0 0)
                "NEW_TAG1"
                "New Value 1"
                (getvar 'textsize)
                "New Attribute 2"
                (vlax-3D-point 0 (- (* 1.5 (getvar 'textsize))))
                "NEW_TAG2"
                "New Value 2"
            (command "_.attsync" "_N" blk)
    (princ)
(vl-load-com) (princ)
Thanks.
Replies (53)
Message 41 of 54
Kyle.para
Daniel,
We still use this code till this day. What are you trying to do exactly?
Message 42 of 54
Dany.jee
Hello Kyle,
I have a library with a lot of symbol/ block, without attributes, I i would like to add them with a lisp quickly, All the same attributes for all block.
When I run the first code, the attribute created is on the center of the block, so it appaears in the middle of the view.
I am looking to move it down to let the symbol view free.
I don't know how to define (vlax-3D-point 72 84)  to move it.
And I need part of them to be invisible too.
I attech the dwg  a part of the library. In the first  red Rectangle there is a "Native" block , then explode view with attributes I need in, and the last is the "FINAL block".
I hope I was enought clear.
If I know how to set the location of the attibutes and the invisibility I will repeat the code for all attributes.
Waiting for you enlightment.
Cheers
D.
Message 43 of 54
Kyle.para
Ah I see now what you mean. I thought this was a different code at first. If I understand your question correctly you want to change the position where they land in the block? You need to adjust the values 72 and 84 those are your x y values in the block. You can also make them negative depending on the 0 point. Hope that helps.
As for the invisibility I thought it was already in the code or are they being generated visible currently?
Message 44 of 54
dlanorh
(vlax-3d-point) requires a list
(vlax-3d-point (list 72. 84. 0.))
I am not one of the robots you're looking for
Message 45 of 54
Dany.jee
Yes that's it, But changing the values of x and y didn't do nothing..
I solved to do it, but i really don't know how I did.. haha.
Now I have a probleme with:
(vlax-put def 'Alignment 4)
(vlax-put def acAlignmentmiddle)
I don't know How to set the attribut Alignementinmiddle .. not the good syntax I think..
here is the new code:
(defun c:addatribs ( / ss i blk blks def )
    (and
       (setq ss (ssget '((0 . "INSERT"))))
       (setq i (sslength ss))
       (while (> i 0)
          (setq blk (cdr (assoc 2 (entget (ssname ss (setq i (1- i)))))))
          (if (not (vl-position blk blks))(setq blks (cons blk blks)))
    (foreach blk blks
;------------ATTRIBUT 01 ---------------------------------------------------
		3
             "DENOMBREMENT"
             (vlax-3D-point 0 +9)
		;(vlax-put def 'Alignment 4)
		;(vlax-put def acAlignmentmiddle)
             "DENOMBREMENT"
             "xxxx"
;------------ATTRIBUT 02 ---------------------------------------------------
		3
             "TYPE/CLASSE"
             (vlax-3D-point 0 +5)
             "TYPE/CLASSE"
             "xxxx"
;------------ATTRIBUT 03 ---------------------------------------------------
		3
             "CIRCUIT_ELEC/ADR_KNX/DALI_#2"
             (vlax-3D-point 0 -7)
             "xxxx"
;------------ATTRIBUT 04 ---------------------------------------------------
		3
             "CIRCUIT_ELEC/ADR_KNX/DALI_#3"
             (vlax-3D-point 0 -11)
             "xxxx"
;------------ATTRIBUT 05 ---------------------------------------------------
		3
             "CIRCUIT_ELEC/ADR_KNX/DALI_#4"
             (vlax-3D-point 0 -15)
             "xxxx"
;------------ATTRIBUT 06 ---------------------------------------------------
		3
             "CIRCUIT_ELEC/ADR_KNX/DALI_#5"
             (vlax-3D-point 0 -19)
             "xxxx"
;------------ATTRIBUT 07 ---------------------------------------------------
		3
             acattributemodeinvisible
             "DESIGNATION_ZONE"
             (vlax-3D-point 0 -23)
             "DESIGNATION_ZONE"
             "xxxx"
	;(vlax-put AttObj 'Alignment acAlignmentmiddle) ;; 4
    (princ)
And I am looking a way to delete the old attribut an block could have before applying this lisp.
Thank U in advance for your reply 🙂
Message 46 of 54
devitg
I got it from your previous post
Message 47 of 54
Dany.jee
I don't understand  what you want to say?🤔
Message 48 of 54
devitg
Hi@Dany.jee , I erased my post , as I ask for a sample , and I saw you had uploaded in a previous post .
I put my finger in movement, before  I start my brain neurons.
Message 49 of 54
Dany.jee
Hi @devitg, do you have some clue about the alignment method in my lisp?
I am sur it's very simple but I am not a coder.. yet
    (and
       (while (> i 0)
    (foreach blk blks
		3
             "DENOMBREMENT"
             "DENOMBREMENT"
             "xxxx"
		3
             "TYPE/CLASSE"
             "TYPE/CLASSE"
             "xxxx"
		3
             "xxxx"
		3
             "xxxx"
		3
             "xxxx"
		3
             "xxxx"
		3
             "DESIGNATION_ZONE"
             "DESIGNATION_ZONE"
             "xxxx"
;------------ATTRIBUT 08 ---------------------------------------------------
		3
             "COSWIN"
             (vlax-3D-point 0 -27)
             "COSWIN"
             "xxxx"
;------------ATTRIBUT 09 ---------------------------------------------------
		3
             "NUM_LOCAL"
             (vlax-3D-point 0 -31)
             "NUM_LOCAL"
             "xxxx"
;------------ATTRIBUT 10 ---------------------------------------------------
		3
             "POSITION_BORDEREAU"
             "xxxx"
;------------ATTRIBUT 11 ---------------------------------------------------
		3
             "DENOMINATION"
             (vlax-3D-point 0 -35)
             "DENOMINATION"
             "xxxx"
;------------ATTRIBUT 12 ---------------------------------------------------
		3
             "FOURNISSEUR"
             (vlax-3D-point 0 -39)
             "FOURNISSEUR"
             "xxxx"
;------------ATTRIBUT 13 ---------------------------------------------------
		3
             "MARQUE"
             (vlax-3D-point 0 -43)
             "MARQUE"
             "xxxx"
;------------ATTRIBUT 14 ---------------------------------------------------
		3
             "N°_DE_SERIE/REF"
             (vlax-3D-point 0 -47)
             "N°_DE_SERIE/REF"
             "xxxx"
;------------ATTRIBUT 15 ---------------------------------------------------
		3
             "ANNEE_DE_FABRICATION"
             (vlax-3D-point 0 -51)
             "xxxx"
;------------ATTRIBUT 16 ---------------------------------------------------
		3
             "DEBUT_DE_GARANTIE"
             "DEBUT_DE_GARANTIE"
             "xxxx"
;------------ATTRIBUT 17 ---------------------------------------------------
		3
             "DUREE_DE_GARANTIE"
             (vlax-3D-point 0 -55)
             "DUREE_DE_GARANTIE"
             "xxxx"
;------------ATTRIBUT 18 ---------------------------------------------------
		3
             "REF_FICHE_TECHNIQUE"
             (vlax-3D-point 0 -59)
             "xxxx"
;------------ATTRIBUT 19 ---------------------------------------------------
		3
             "ATTRIBUT_1"
             (vlax-3D-point 0 -63)
             "ATTRIBUT_1"
             "xxxx"
;------------ATTRIBUT 20 ---------------------------------------------------
		3
             "ATTRIBUT_2"
             (vlax-3D-point 0 -67)
             "ATTRIBUT_2"
             "xxxx"
;------------ATTRIBUT 21 ---------------------------------------------------
		3
             "ATTRIBUT_3"
             (vlax-3D-point 0 -71)
             "ATTRIBUT_3"
             "xxxx"
	;(vlax-put 'Alignment acAlignmentmiddle) ;; 4
    (princ)
 And I found another lisp to delette all attributes
This one:  And I'm trying to combine them into one but, just the first one is executed
(defun tl_fld (v1 v2) (cdr (assoc v1 v2)))
(defun c:attdel2 (/	     ss		cnt	   blk
		  blkdat     blknam	blktblnam  blknewdat
		  blktbldat  newblkdat	atk_dbug   nextent
		  nextentdat nextenttyp	endblklst
  (command "undo" "group")
  (setq atk_dbug nil)
  ;;  (setq atk_dbug T)
  (if (setq ss (ssget (list (cons 0 "insert") (cons 66 1))))
    (progn
      (setq cnt -1)
      (repeat (sslength ss)
	(setq blk	(ssname ss (setq cnt (1+ cnt)))
	      blkdat	(entget blk)
	      blknam	(tl_fld 2 blkdat)
	      newblknam	(strcat blknam "_na")
	      blknewdat	(subst (cons 2 newblknam)
			       (assoc 2 blkdat)
			       blkdat
	      blknewdat	(subst (cons 66 0)
			       (assoc 66 blknewdat)
			       blknewdat
	(if (not (tblsearch "block" newblknam))
	  (progn
	    (setq blktblnam (tblobjname "block" blknam)
		  blktbldat (entget blktblnam)
		  newblkdat (subst (cons 2 newblknam)
				   (assoc 2 blktbldat)
				   blktbldat
		  newblkdat (subst (cons 70 (- (tl_fld 70 blktbldat) 2))
				   (assoc 70 blktbldat)
				   newblkdat
	    (if	(entmake newblkdat)
	      (progn
		(if atk_dbug
		  (princ "\nStarting new block definition . . . ")
		(setq nextent	 (entnext blktblnam)
		      nextentdat (entget nextent)
		      nextenttyp (tl_fld 0 nextentdat)
		(while (and nextenttyp (/= nextenttyp "ENDBLK"))
		  (if (/= nextenttyp "ATTDEF")
		    (if	(not (entmake nextentdat))
		      (princ "\nCan't make subentity.")
		      (if atk_dbug
			(princ (strcat "\nAdding "
				       nextenttyp
				       " as subentity "
				       (itoa xcnt)
		    (if	atk_dbug
		      (princ "\nSkipping attribute definition.")
		  (setq	nextentdat
				   nil
			nextenttyp nil
		  (if (setq nextent (entnext nextent))
		    (setq
		(setq endblklst	(list (cons 0 "endblk")
				      (cons 100 "AcDbBlockEnd")
		(if (not (entmake endblklst))
		  (princ "\nCan't terminate block definition")
	      (princ "\nCan't start new block definition.")
	(if (tblsearch "block" newblknam)
	  (progn
	    (entdel blk)
	    (entmake blknewdat)
      (setq ss nil)
  (command "undo" "end")
  (tl_$tlp)
hanks for your help 🙂
Message 50 of 54
Dany.jee
I still didn't fins the solution, anyone have a clue to center the attributes?
I am reaaly stuck with that.
Dany
Message 51 of 54
Hey Daniel did you try:
;(vlax-put def acAlignmentcenter)
Message 52 of 54
hunyar.adam.mate.provill
Hello everyone!
I'm working with a lot of blocks and I need to add some extra attributes to each of them. Existing blocks work with parameters and dynamic attributes. When I use these lisp's they work perfectly as long as I use the ATTSYNC command. In this case, the new attributes are removed from the blocks. I noticed that if I delete all the parameters from my existing block, new parameters can remain in my old blocks, but I have to re-parameterize them all.
Is there any solution?
Message 53 of 54
Kyle.para
Hey Hunyar, you can try to open up the  block editor and then open up the parameter manager in there. I believe you have to reassign the new attribute to the old parameter.
Cheers, KP
Message 54 of 54
Yes but it is very time consuming and this is the reason why i am lookig for better solution.
The new attributes do not have to work with parameters. Sometimes i need to determine elements location, foor exampler name of room or room numbers. I want to prevent that use ATTSYNC command and lose everything what I did before.
