LISP to select a set object in alternate pattern or selection .
Kenn.O
Message 1 of 23
Kenn.O
Dear ALL,
new on this forum.
Good day.
Very much appreciate if some one can share/ help for a LISP. to select an alternate object in a set of object.
1) select set of object
2) select with alternate pattern ( also for Horizontal lines)
Best regards & thank you very much,
Kenneth
Accepted solutions (3)
Replies (22)
Message 21 of 23
komondormrex
let us mix it in one phial. with updated command you can mark with mleader all selected lines with left click  right after  the selection is confirmed and before space to alternate the selection is pressed.
Message 22 of 23
komondormrex
i am not sure i did understand what do you want to change.
mark selection set of lines if its length less than or equal 3 items with mleader with what text?
Message 23 of 23
ngoclinhbmt
Thank you for your attention
I want to change the select line/polyline to point or text following your code, please view my picture. thanks so much
My routine:
1/ Select 2 or 3 points/text with the same content.
2/Draw pline connect them and insert the donut/ block
Please view my picture. thanks so much!!!
