lisp to Save & Quit on 1st layout
alx86
alx86
I've maid a Lisp routine that, in sequence, do the following:
qsave
go to model space
zoom extent
switch to the first layout tab
lock all viewport
zoom extent
close
The routine work perfectly except for 1 thing. At the end of the routine, instead of openning the dialog box asking to save or not, it's asking in the command bar wether or not I want to discard changes... Is there a way that it display the dialog box instead?
here the routine:
;---Exit and Save 1st Page
  (vl-load-com)
(defun c:qs (/ acdoc aclyt app fstlyt lyts newlyt order)
 (command "qsave" "model")
  (setq app   (vlax-get-acad-object)
        acdoc (vla-get-activedocument app)
        aclyt (vla-get-activelayout acdoc)
        lyts  (vla-get-layouts acdoc)
        order (vla-get-taborder aclyt)
  (command "_.PSPACE" "mview" "l" "on" "all" "")
  (vla-ZoomExtents app)
  (if (and (/= order 0) (> (getvar 'CVPORT) 1))
    (command "_.pspace")
  (vlax-for lyt lyts
    (if (= (vla-get-taborder lyt) (1+ order))
      (setq newlyt lyt)
    (if (= (vla-get-taborder lyt) 1)
      (setq fstlyt lyt)
  (if newlyt
    (vla-put-activelayout acdoc newlyt)
    (vla-put-activelayout acdoc fstlyt)
   (command "close")
  (princ)
ВeekeeCZ
I found this thread...
alx86
Thanks a lot 🙂 It worked perfectly
here's the final version if someone is interested:
;---Shortcut = QS
  (vl-load-com)
  (vlax-for lyt lyts
      (setq newlyt lyt)
      (setq fstlyt lyt)
  (if newlyt
(vla-sendcommand
(vla-get-activedocument (vlax-get-acad-object))
".close ")
  (princ)
