lisp to rotate 180 degrees (AutoCAD 2004)
Is there a lisp program availabe that would enable me to rotate any selected text 180 degrees relative to the current position of the text? I tried the TORIENT command, but that seems to work by absolute rotation rather than just relative to the current position of the text. Thanks for any advice on this.
Here is a quickie....
(defun c:Text180 (/ ss i ename data pair)
(setq ss (ssget '((0 . "TEXT,MTEXT"))))
(if ss
(progn
(setq i -1)
(repeat (sslength ss)
(setq ename (ssname ss (setq i (1+ i))))
(setq data (entget ename))
(setq pair (assoc 50 data))
(entmod (subst (cons 50 (+ pi (cdr pair))) pair data))
(princ)
-Jason
Member of the Autodesk Discussion Forum Moderator Program
"rob8397" wrote in message news:f196237.-1@WebX.maYIadrTaRb...
Jason,
Thanks very much for your help with this. The lisp routine works great!
Rob
You're welcome.
-Jason
"rob8397" wrote in message news:f196237.1@WebX.maYIadrTaRb...
> Jason,
> Rob
