Lisp to recreate multiple xclip borders
Message 1 of 8
I am searching for a lisp routine that would recreate multiple xclip borders and assign generated plines on a new layer.
I have found some directions in other post but its no use for me as I cnat really program... still.
(defun xclip-points (ent / e d)
(while (setq e (cdr (assoc 360 (entget ent)))) (setq ent e))
(if (member '(0 . "SPATIAL_FILTER") (setq d (entget ent)))
(cons
(eq 1 (cdr (assoc 71 d)))
(apply 'append
(mapcar '(lambda (x) (if (eq 10 (car x)) (list (cdr x)))) d)
Returns '(flag point point point)
Clip on: (T (670466.0 678736.0) (671585.0 678520.0) ...)
Clip off: (nil (670466.0 678736.0) (671585.0 678520.0) ...)
No clip: nil
Any ideas?
Much appriciated
Jan
Replies (7)
Message 2 of 8
hmsilva
Maybe something like this
(defun c:recreate (/ xclip-points mk_pl lst lsta ss)
      (cons
        (apply 'append
                          (if (eq 10 (car x))
                            (list (cdr x))
                       d
  (defun mk_pl (pt-lst /)
    (entmake
      (append
        (list '(0 . "LWPOLYLINE")
              '(100 . "AcDbEntity")
              '(100 . "AcDbPolyline")
              (cons 90 (1+ (length pt-lst)))
              '(8 . "TRAB")
              '(70 . 1)
        (mapcar (function (lambda (x) (cons 10 x))) pt-lst)
  (if (setq ss (ssget '((0 . "INSERT"))))
    (repeat (setq i (sslength ss))
      (setq ent (ssname ss (setq i (1- i)))
            lst (xclip-points ent)
      (if (not (null lst))
        (progn
          (setq lst (cdr lst))
          (if (> (length lst) 2)
            (mk_pl lst)
            (if (= (length lst) 2)
              (progn
                (setq lsta (cons (car lst) lsta)
                      lsta (cons (list (car (car lst)) (cadr (cadr lst))) lsta)
                      lsta (cons (cadr lst) lsta)
                      lsta (cons (list (car (cadr lst)) (cadr (car lst))) lsta)
                      lsta (reverse lsta)
                (mk_pl lsta)
  (princ)
Untested...
Henrique
Message 3 of 8
It runs well! Thanks a lot...
I guess this part of code is dealing with color and Linetype... what should i put to get color layer 222,222,222 and hidden linetype? And BTW where can I find some documentation about these arguments.
Cheers
Jan
Message 4 of 8
hmsilva
You're welcome, Jan.
To create a layer, we can entmake it, but we have to write much more code, we need to test if layer exists, if linetype is already loaded, if not load it first, then entmake the layer with the specific linetype,...
The easiest way is to use the command LAYER to create the layer with the specific linetype, if it's not loaded, the command will load it.
(if (not (tblsearch "LAYER" "YourLayerName"))
  (command "_.layer" "_N" "YourLayerName" "_C" "_T" "222,222,222" "YourLayerName" "_L" "Hidden" "YourLayerName" "")
In the code to entmake the lwpolyline, I just set the layer name (dxf 8) to 'TRAB', change the layer name there and in the previous code to the correct LayerName, and put this code snippet just before
You should find the DXF reference at the help files,
Developer Documentation -> DXF Reference
Hope that helps
Henrique
Message 5 of 8
As expected I will need some time to contemplate information which you gave me 🙂
But thanks a lot.
If not too much trouble can you alter the code to recreate boundaries of viewports insetad of xclips.
Sorry for the trouble.
Jan
Edit: I did something wrong..
      (cons
        (apply 'append
                          (if (eq 10 (car x))
                            (list (cdr x))
                       d
    (entmake
	(if (not (tblsearch "LAYER" "TestLayer"))
  		(command "_.layer" "_N" "TestLayer" "_C" "_T" "222,222,222" "TestLayer" "_L" "Hidden" "TestLayer" "")
        (progn
            (mk_pl lst)
              (progn
                      lsta (reverse lsta)
                (mk_pl lsta)
  (princ)
Message 6 of 8
hmsilva
You're welcome, Jan,
try
      (cons
        (apply 'append
                          (if (eq 10 (car x))
                            (list (cdr x))
                       d
    (entmake
      (append
              '(8 . "TestLayer")
              '(70 . 1)
        (progn
            (mk_pl lst)
              (progn
                      lsta (reverse lsta)
                (mk_pl lsta)
  (princ)
Henrique
Message 7 of 8
It works, of course.
I didnt understand that you have to first make "test layer" and then do the adjustment etc...
Anyhow thank you.
Jan
Message 8 of 8
hmsilva
You're welcome, Jan
Glad I could help
Henrique
