Lisp to multi mirror with several base point.
I hope any one can help to me.
I am trouble to using mirror commend to use with every object. I need to change multi mirror with several base point.
Thanks in advance.
Sujinkutti...
ВeekeeCZ
Post some sample dwg with several objects and draw their mirror lines you want to use for the MIRROR command.
Please refer the below snap.. i have to mirror all block different location, I need like blue box below snap..
Thanks and regards,
Sujikutti.
ВeekeeCZ
(defun c:MirrorHor (/ ss i en pt)
  (if (setq ss (ssget "_:L" '((0 . "INSERT"))))
    (repeat (setq i (sslength ss))
      (setq en (ssname ss (setq i (1- i)))
            pt (cdr (assoc 10 (entget en))))
      (command "_.MIRROR" en "" "_non" (trans pt 0 1) "_non" "@0,1" "_Yes")))
  (princ)
dbhunia
As you asked....
I think you have to mirror all the Blocks without selection .......... If I am right then try this.......
(defun C:MB (/ blk sset N ent pt)
(command "_.CMDECHO" 0)
(setq blk (getstring "\nEnter the name of the Blok to Mirror: "))
(setq sset (ssget "_A" (List '(0 . "INSERT") (cons 2 blk))))
      (repeat (setq N (sslength sset))
      	      (setq ent (ssname sset (setq N (- N 1))))
              (setq pt (cdr (assoc 10 (entget ent))))
              (command "_.MIRROR" ent "" "_non" (trans pt 0 1) "_non" "@0,1" "_Yes")
(command "_.CMDECHO" 1)
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
