lisp to label cross section
marlance
Message 1 of 1
marlance
Hi all,
I modified this code again based on the chainage lisp posted here.
(defun c:polen (/ datum dist ld obj plen plength pt row rowh tox txtpos)
  (vl-load-com)
(defun _text (p b o h c)
       (entmake
	 (append
	   '((0 . "TEXT")
	     (100 . "AcDbEntity")
	     (67 . 0)
	     (410 . "Model")
	     (7 . "GHD Standard Arial")
	     (8 . "C-CH_LABL")
	     (100 . "AcDbText")
	   (list (cons 10 (polar p (+ b PI) tox))
	   (list (cons 40 h))
	   (list (cons 1 (strcat ""  (if (setq ld (nth (strlen (rtos  c 2 0)) '(x  "00" "")))
				   	ld "")
				 (rtos c 2 2))))
	   (list (cons 50 (+ b (/ PI 2) )))
	   '((41 . 1.0)
	     (51 . 0.0)
	     (71 . 0)
	     (72 . 0)
	     (11 0.0 0.0 0.0)
	     (210 0.0 0.0 1.0)
	     (100 . "AcDbText")
	     (73 . 0)
  ;;;		Modified by pBe		;;;
  (defun _ang (en d pt)
    (+ (angle '(0.0 0.0 0.0)
	      (vlax-curve-getfirstderiv
		en
		(vlax-curve-getparamatpoint en pt)
       (* pi 1.5)
(setq datum (getdist"\nEnter datum: "))
(setq height (getdist"\nEnter text height: "))
(setq row (getreal"\nChoose row: "));;;;select where to place text
(setq tox (/ height 5));;offset from x axis
(setq rowh (* (* (/ height 2) 10)-1))
(setq txtpos (+ (* rowh row)(/ height 2)))
(setq dist 10)
(setq offset 2);0
(setq to 2);0
  (setq	ss    (ssget)
	count 0
  (repeat (sslength ss)
    (setq ent	   (ssname ss count)
	  obj	   (vlax-ename->vla-object ent)
	  chainage dist
   plen (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj))
    (setq p (vlax-curve-getstartpoint ent))
    (setq p2 (vlax-curve-getendpoint ent))
(setq pt (list (car p) (+ (cadr p) txtpos )));;;;;;insertion point of text
    (setq plength ( + datum plen))
    ;;;	Additional option / re-arrange sequence		;;;
    ;;;;modified by mircea to get the elevation value of polyline
    (_text pt (_ang ent chainage p) to height plength)
    ;;; 	Start/Mid/End mode iI Length is less than or equal twice the value of dist variable	;;;
    (if	(<= (setq ln (vlax-curve-getdistatparam
		       ent
		       (vlax-curve-getendparam ent)
	    (* 2 dist)
      (while
	(setq point1 (vlax-curve-getPointAtDist obj chainage))
	(setq bearing (_ang ent (+ chainage dist) point1))
	(setq chainage (+ chainage dist))
    (setq count (1+ count))
  (princ)
the attached image (on the middle) is generated by this code by selecting the yellow lines.
can it be possible to achieve the image on the right side?
regards,
roldan
Replies (0)
