Lisp to isolate layers that have multiple hatches
As the title suggests, any idea?
ВeekeeCZ
Perhaps like this?
(defun c:LayIsoWHatches ( / def lay sel lst)
  (while (setq def (tblnext "LAYER" (null def)))
    (and (setq lay (cdr (assoc 2 def)))
         (setq sel (ssget "_X" (list '(0 . "HATCH") (cons 8 lay))))
         (> (sslength sel) 1)
         (setq lst (cons lay lst))))
  (if lst
    (progn
      (command "_.-LAYER"
               "_Off" "*" "_Yes")
      (foreach l lst
        (command "_On" l))
      (command "_Set" (car lst) "")))
  (princ (strcat "\n" (itoa (length lst)) " layers isolated."))
  (princ)
Hello again,
Is possible to make this to isolate layers that have multiple polylines?
ВeekeeCZ
Just replace "HATCH" with "LWPOLYLINE".
Worked, how to make it isolate layers without any polylines?
Thank you
ВeekeeCZ
(not (ssget "_X" (list '(0 . "LWPOLYLINE") (cons 8 lay))))
Thank you a lot!
