Lisp to insert Xrefs from different folders
sambaldan
Message 1 of 10
sambaldan
I've been working on a lisp to help us set up new drawings. It works in the way that as a company we use the same DWG names for all of the same xrefs even between different projects. i.e. 2D First Floor General Arrangement  =  2D-XA-01.dwg / 2D Second Floor RCP = 2D-XA-02-RCP.dwg etc etc
See my attempt below which may make things a little clearer:
(defun c:01ABC ( / )
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0341 - ABC\\123\\XREF\\2D XREFS\\2D-XA-01.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0341 - ABC\\123\\XREF\\2D XREFS\\2D-XA-01-RCP.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0341 - ABC\\123\\XREF\\2D XREFS\\2D-XA-01-FURNITURE.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0341 - ABC\\123\\XREF\\3D XREFS\\3D-XA-01.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0341 - ABC\\123\\XREF\\2D XREFS\\2D-XS-02.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0341 - ABC\\123\\XREF\\3D XREFS\\3D-XS-02.dwg" "0,0,0" "" "" "") (princ)
(command "zoom" "e")
(princ))
(defun c:01XYZ ( / )
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0342 - XYZ\\123\\XREF\\2D XREFS\\2D-XA-01.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0342 - XYZ\\123\\XREF\\2D XREFS\\2D-XA-01-RCP.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0342 - XYZ\\123\\XREF\\2D XREFS\\2D-XA-01-FURNITURE.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0342 - XYZ\\123\\XREF\\3D XREFS\\3D-XA-01.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0342 - XYZ\\123\\XREF\\2D XREFS\\2D-XS-02.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0342 - XYZ\\123\\XREF\\3D XREFS\\3D-XS-02.dwg" "0,0,0" "" "" "") (princ)
(princ))
(defun c:02ABC ( / )
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0341 - ABC\\123\\XREF\\2D XREFS\\2D-XA-02.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0341 - ABC\\123\\XREF\\2D XREFS\\2D-XA-02-RCP.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0341 - ABC\\123\\XREF\\2D XREFS\\2D-XA-02-FURNITURE.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0341 - ABC\\123\\XREF\\3D XREFS\\3D-XA-02.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0341 - ABC\\123\\XREF\\2D XREFS\\2D-XS-03.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0341 - ABC\\123\\XREF\\3D XREFS\\3D-XS-03.dwg" "0,0,0" "" "" "") (princ)
(princ))
(defun c:02XYZ ( / )
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0342 - XYZ\\123\\XREF\\2D XREFS\\2D-XA-02.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0342 - XYZ\\123\\XREF\\2D XREFS\\2D-XA-02-RCP.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0342 - XYZ\\123\\XREF\\2D XREFS\\2D-XA-02-FURNITURE.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0342 - XYZ\\123\\XREF\\3D XREFS\\3D-XA-02.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0342 - XYZ\\123\\XREF\\2D XREFS\\2D-XS-03.dwg" "0,0,0" "" "" "") (princ)
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0342 - XYZ\\123\\XREF\\3D XREFS\\3D-XS-03.dwg" "0,0,0" "" "" "") (princ)
(princ))
 I understand i'm far from spectacular at writing these but at the moment it works great. For example, if i want to insert level 2 XREFS for project XYZ i simply type 02XYZ
The project numbers i.e. 0341/0342 is always changing as new jobs come in and their ABC/XYZ values change also so my lisp would require me to adapt/update it every time a new project is started.
My question is whether there is a way to load the XREFS from the folder after selecting what project i want or having some sort of wild card so when prompted for the job number it will automatically read for folders containing that job number and follow the path through there and load xrefs from
\\123\\XREF\\3D XREFS\\etc.dwg
onwards
I understand this probably isn't a 5 minute piece of assistance and your help is greatly appreciated.
Thank you in advance for any help
Sam
Replies (9)
Message 2 of 10
pbejse
Sam
Use a template, better yet, look into sheets sets.
Or even this..
Message 3 of 10
pbejse
Sam
I may have something similar to this in the past, and few ideas to streamline the process.  its way past my bed time. I'll check in tomorrow.
Cheers
Message 4 of 10
sambaldan
I appreciate you looking at this for me.
(command "_-xref" "overlay" "C:\\Users\\home\\Desktop\\LISP TEST\\0342 - XYZ\\123\\XREF\\3D XREFS\\0342-3D-XS-03.dwg" "0,0,0" "" "" "") (princ)
Last night in the absence from my office i missed the job number (0342-) which i have indicated in bold above. I'm not sure if this will affect anything i previously mentioned.
Message 5 of 10
pbejse
Have you had time to explore Sheet Set Manager?
You can select a template that fits your project requirement
You can setup your title blocks and any other Xrefs that goes with the project, page setup, including blocks for annotations, publish and e-transmit. folder structures even.
I would gladly help you with your code, but at least have a look at what Sheet Set Manager can do for you, it has a lot to offer.
I will tinker with your code and post it later.
Cheers
Message 6 of 10
sambaldan
I'll have a look in to it - never used it before so ill see if i can figure it out.
Message 7 of 10
pbejse
Quick, Is this the format for project number 0342 - XYZ numbers - letters? or sometimes its a mix?  number - numbers/letters
or
always numbers and dash? space between dash? or you can just type in the prefix?
Message 8 of 10
sambaldan
Folder is always Job Number + space + dash + space + job title (03xx - Job Title) however this may be in the format of (03xx - 100 Smith Street)
DWG Files are always Job Number+dash+XA/XS
Message 9 of 10
pbejse
To make it simple, just type in the prefix
(Defun c:PXREF ( / project prefix)
      (if (and
		(setq project (acet-ui-pickdir "Select Project Folder" "C:\\Users\\YourFoldername"))
        	(setq prefix  (lisped "PREFIX"))
        (progn
                 (Foreach projectxref '("2D-XA-02.dwg"
                                            "2D-XA-02-RCP.dwg"
                                            "2D-XA-02-FURNITURE.dwg"
                                            "3D-XA-02.dwg"
                                            "2D-XS-03.dwg"
                                            "3D-XS-03.dwg")
                      (if (findfile (setq xref2attach (strcat project "\\" prefix "-" projectxref)))
                          (command "_-xref" "overlay" xref2attach "0,0,0" "" "" "")
Message 10 of 10
pbejse
And if the xref files do not exist on the selected folder
(Defun c:PXREF ( / sourceXREF project prefix)
(setq sourceXREF "C:\\Users\\YourFolder\\Blocks\\") (if (and (setq project (acet-ui-pickdir "Select Project Folder" "C:\\Users\\YourFolder")) (setq prefix (lisped "PREFIX"))) (progn (Foreach projectxref '("2D-XA-02.dwg" "2D-XA-02-RCP.dwg" "2D-XA-02-FURNITURE.dwg" "3D-XA-02.dwg" "2D-XS-03.dwg" "3D-XS-03.dwg") (if (or (findfile (setq xref2attach (strcat project "\\" prefix "-"projectxref))) (vl-file-copy (strcat sourceXREF prefix "-" projectxref) xref2attach) ) (command "_-xref" "overlay" xref2attach "0,0,0" "" "" "") ) ) ) ) )
The program will make a copy from your library to specified folder
or even
(Foreach projectxref (vl-directory-files project "*.dwg")
    	 (command "_-xref" "overlay" (strcat project "\\" projectxref) "0,0,0" "" "" "")
EDIT: No need for Findfile function
HTH
MORE EDIT: HANG ON A MINUTE. THIS IS EXACTLY LIKE XREF MANAGER 'S FUNCTION Smiley Very Happy I OVER ANALYZE EVERYTHING THESE DAYS. need a break 🙂
