Lisp to find XREF insertion point and use it for a new xref
Hopefully someone can help me.
With Lisp I want to find the insertion point of an xref called "layout" and want to use these coordinates to insert a block called "demolition".
Thank you in advance.
Kent1Cooper
Try something like [untested]:
(defun C:DALI (/ ss); = Demolition At Layout Insertion
  (if (setq ss (ssget "_X" '((0 . "INSERT") (2 . "layout"))))
    (command "_.insert" "demolition" "_none" (cdr (assoc 10 (entget (ssname ss 0)))) "" "" "")
That assumes you don't have an ordinary Block also called "layout" in the drawing, and that you want "demolition" inserted at a scale of 1 and rotation of 0, and that "demolition" is not defined for only uniform scaling.
Kent Cooper, AIA
Thanks!
You're correct and this works fine.
grx.
john.uhden
I spiffed up @Kent1Cooper's contribution a little so you don't have to worry about an ordinary block named "Layout."
(defun C:DALI ( / blocks block ss p); = "Demolition" At "Layout" Insertion
   (and
     (setq Blocks (vlax-get (vla-get-activedocument (vlax-get-acad-object)) 'blocks))
     (setq block (vla-item blocks "Layout"))
(or (/= (vlax-get block 'isxref) 0)
(prompt "\n'Layout' is the name of an ordinary block")
) (setq ss (ssget "_X" '((0 . "INSERT") (2 . "Layout")))) (setq p (cdr (assoc 10 (entget (ssname ss 0))))) (vl-cmdf "_.insert" "demolition" "_none" p "" "" "") ) )
But I think I left out checking for Model vs. Paper space.
@Kent1Cooper:  Do we need to maybe (trans p)?
John F. Uhden
bijan.yazdaniAR2WN
that's lovely John.
just wondering if we could have a lisp to inset a block or xref in ucs coordinates without changing it to wcs
thx
Jon
Kent1Cooper
@bijan.yazdaniAR2WN wrote:
.... if we could have a lisp to inset a block or xref in ucs coordinates without changing it to wcs ....
Yes, as @john.uhden questioned, I think there a (trans) function would be appropriate, to convert the WCS coordinates of the insertion point to the current UCS.  In my shorter version:
            (trans (cdr (assoc 10 (entget (ssname ss 0)))) 0 1) "" "" ""
Kent Cooper, AIA
john.uhden
My apologies.  I included some faulty code...
The vla-item method will return an error if the block name does not exist.  Whereas the pre-VisualLisp is simpler and returns nil if the block name does not exist:
(tblobjname "block" "<name>")
John F. Uhden
