lisp to fill table
lisp to fill table
islerahmet06
lisp to fill table
islerahmet06
Hello again 🙂
I have a dwg to define parts, in dwg there is a description for every parts to define (thickness, lenght quantity) and have a table for all parts,
for example my first part  has 2mm thickness, 1000mm length, 2000mm width
i write it as (L2x1000...……..2000) and i write samething to table, and also quantities...
When i finish my part and define it, i must write everything at table, is there any easy way to do this?
Thanks for your time.
jamieq
Do you need code to get all the parts and add them to a list with quantities?
Assuming you already have that, and your list is in the format:
(list
'("\(L2x1000...……..2000\)" "20")
'("\(L3x1100...……..2100\)" "40")
You can use this create and fill a table. I've put variable values in square brackets.
(setq *ms* (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(setq myTable (vla-AddTable *ms* (vlax-3d-point pt) (+ 2 (length lst)) 2 24 120)) ; makes a table with as many rows as length lst plus two for the title and headers, 2 columns, row height 24 and cell width 120
(vla-setcelltextheight myTable 0 0 18) ; title text height 18, to stand out
(setq y 1)
(repeat (1+ (length lst))
	(setq x 0)
	(repeat 2 ; adjust for number of columns
		(vla-setcelltextheight myTable x y 12) ; cell text height 12
		(vla-setCellAlignment myTable x y 5) ; cell alignment middle center
		(setq x (1+ x))
	(setq y (1+ y))
(vla-setText mytable 0 0 "Parts") ; fill in title
(vla-setText mytable 1 0 "Description") ; fill in header
(vla-setText mytable 1 1 "Quantity") ; fill in header
(setq row 2)
(foreach item lst
	(vla-setText mytable row 0 (car item)) ; fill in description
	(vla-setText mytable row 1 (last item)) ; fill in quantity
	(setq row (1+ row))
(vlax-release-object myTable)
(vlax-release-object *ms*)
This is modified slightly from some code I use myself. It also assumes units are inches, which I mention since you put mm in your descriptions. You'll need to adjust for different units settings.
jamieq
Only just realized I didn't put variables in square brackets. Please disregard that.
