LISP to fill custom drawing properties from textfile
geraldbossink
Message 1 of 12
geraldbossink
I'm looking for a LISP that reads a txt-file in the same directory as the drawing. In the txt-file are two lines with text. First line is the client name, second line is the project name. In the drawing properties I want them filled in in the Custom Tab (as shown in the attached image). Is there some kind of LISP available for this?
Replies (11)
Message 2 of 12
pbejse
@geraldbossink wrote:
I'm looking for a LISP that reads a txt-file in the same directory as the drawing. In the txt-file are two lines with text. First line is the client name, second line is the project name. In the drawing properties I want them filled in in the Custom Tab ..
The name of the text file is the same as the drawing name with a .TXT extension?
The Custom Opdrachtgever and Project already exists or sometimes not?
(defun c:demo ( / aDoc DwgProps availableData source inc opf)
(setq aDoc     (vla-Get-ActiveDocument (vlax-Get-Acad-Object))
      DwgProps (vla-Get-SummaryInfo aDoc)
  (if (and
	(findfile
	  (setq Source (Strcat (getvar 'dwgprefix) "projectgegevens.txt")))
	  (repeat (setq inc (vla-numcustominfo DwgProps))
		  (vla-GetCustomByIndex DwgProps (setq inc (1- inc)) 'key 'value)
		  (setq availableData (cons (list key value inc) availableData))
          (Vl-every '(lambda (cn)
		       (assoc cn availableData))
		    (setq CustomNames '("Opdrachtgever" "Project")))
    (progn
      (setq opf (open Source "r"))
      (foreach itm CustomNames
       (setq a (read-line opf))
		(vla-SetCustomByKey DwgProps itm a)
      (close opf)
    )(princ)
HTH
Message 3 of 12
geraldbossink
@pbejse: The dir will contain multiple drawings, so the txt-file will have a general name, let's say 'projectgegevens'. The idea is:
1. txt-file is created
2. new drawing is created, LISP runs and fills the custom properties
3. Drawing header contails fields for client and project, that are automatically filled when the custom properties are filled
4. When adding a new layout to the drawing, a new header is inserted and automatically filled.
At the start of the project the txt-file is created, so for every new drawing the txt-file exists.
Hope this helps
Message 4 of 12
pbejse
Updated the code at post # 2
Hope that helps
Message 5 of 12
geraldbossink
I'm sorry to inform you, but it doesn't. Saved the code as LISP and ran it, but custom drawing properties remain empty. I tried adding/prefixing 'opdrachtgever' en 'project' in de txt-file, but that didn't work either. Changed 'defun c:demo' to 'defun c:pg', without the requested result.
Message 6 of 12
pbejse
This is key
 If those names does not match the custom property on your drawing the program will not continue.
Have a go with that and let me know
Otherwise attached your drawing here
Message 7 of 12
geraldbossink
Hmmm... Yes, that works. But now I have to fill in "opdrachtgever' and 'project' in the custom properties or have these standard in my template. Isn't it possible to make the LISP do that?
Message 8 of 12
pbejse
That was my question early on.
Better have those on the template files
Or
(defun c:demo (/ aDoc DwgProps availableData source inc opf data)
  (if
    (findfile
     (progn
       (While (setq a (read-line opf))
	 (if (/= a "")
	   (setq data (cons a data))
       (close opf)
	   DwgProps
	   (setq inc (1- inc))
	   'key
	   'value
       (mapcar '(lambda	(a b)
		  (if (assoc a availableData)
		    (vla-SetCustomByKey DwgProps a b)
		    (vla-AddCustomInfo DwgProps a b)
	       '("Opdrachtgever" "Project") (reverse data)
       (vlax-release-object DwgProps)
  (princ)
HTH
Message 9 of 12
geraldbossink
Thnx, works like it should!!! I'm sorry I didn't understand your question in the first place, as English is not my native language.
Why would it be better to have the texts in the template already, instead of the LISP filling them?
Message 10 of 12
pbejse
Good to know it helps.
It's just good practice really  IMO 🙂
Cheers @geraldbossink  🙂
Message 11 of 12
Cudal
@pbejse Hi Patrick. Thank you it works for me. what if two text file. One file for Custom Names and the other for values. The CAD file has no custom properties yet. Thank you!!! hope you can help
Message 12 of 12
pbejse
@Cudal wrote:
...what if two text file. One file for Custom Names and the other for values. The CAD file has no custom properties yet. Thank you!!! hope you can help
That can be arranged
@Cudal
can you check if this works on you AutoCAD
(setq sourceFolder( acet-ui-pickdir "Select Value source fodler" (getvar 'dwgprefix)))
 Copy and paste that on the command line
