Lisp To Extract Data From DwgProps And Place In Excel
Hi
 I was wondering if there was a way through lisp to extract data from dwgprops or the drawing Summary info and create an Excel file. Can someone please help?
_gile
You should be able to get some inspiration from this:
(defun c:dwgprops2csv (/ doc info filename sep file i prop val)
  (setq doc      (vla-get-ActiveDocument (vlax-get-acad-object))
        info     (vla-get-SummaryInfo doc)
        filename (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) "_SummaryInfo.csv")
        sep      (vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")
        file     (open filename "w")
  (foreach prop '("Title" "Subject" "Author" "Keywords" "Comments" "HyperlinkBase" "LastSavedBy" "RevisionNumber")
    (write-line (strcat prop sep (vlax-get info prop)) file)
  (setq i 0)
  (repeat (vla-NumCustomInfo info)
    (vla-GetCustomByIndex info i 'prop 'val)
    (write-line (strcat prop sep val) file)
    (setq i (1+ i))
  (close file)
Gilles Chanteau
GileCAD
GitHub
I am full aware of how to extract the data in several ways however I cant seem to place the data in excel.
Is there someone that could help me with that?
cadffm
Checkout sample code for attribut extraction or other things to excel via activex.
Use your internet search engine:
site:autodesk.com forum vlax excel
Sebastian
