Message 1 of 16
I could use some help with creating a LISP file. I have drawings where some of the polylines do not intersect with a block, because snap was not used. See screenshot and sample file. I would like a lisp file where I could use select similar to select all the blocks (or enter a block name) and then the routine would extend any polylines that have a fuzz factor of 1 or less to the nearest block intersection. Some of my drawings have 100s of these lines so using the extend command manually is tedious.
