Lisp to export layers to KML/KMZ seperately
wian.meier
wian.meier
Good day all,
I've written a LISP for AutoCAD Map 3d, but I can't seem to get the export to work correctly. I can correctly export all the layers to separate shape/Tab files, but not KML.
Am I using the command wrong?
(defun c:test (/ file nam lst table)
(vlax-for lyr
(vla-get-layers
(vla-get-activedocument
(vlax-get-acad-object)
(setq table (cons (vla-get-name lyr) table))
(setq file (LM:browseforfolder "Select a folder" "C:\\" 0))
(while
	(setq lst (car table))
	(setq nam (strcat file "\\" lst))
	(command ".-mapexport" "OGCKML" nam "_N" "_S" "_ALL" lst "*" "_N" "_Proceed")
	(setq table (cdr table))
;; Browse for Folder  -  Lee Mac
;; Displays a dialog prompting the user to select a folder.
;; msg - [str] message to display at top of dialog
;; dir - [str] [optional] root directory (or nil)
;; bit - [int] bit-coded flag specifying dialog display settings
;; Returns: [str] Selected folder filepath, else nil.
(defun LM:browseforfolder ( msg dir bit / err fld pth shl slf )
    (setq err
        (vl-catch-all-apply
            (function
                (lambda ( / app hwd )
                    (if (setq app (vlax-get-acad-object)
                              shl (vla-getinterfaceobject app "shell.application")
                              hwd (vl-catch-all-apply 'vla-get-hwnd (list app))
                              fld (vlax-invoke-method shl 'browseforfolder (if (vl-catch-all-error-p hwd) 0 hwd) msg bit dir)
                        (setq slf (vlax-get-property fld 'self)
                              pth (vlax-get-property slf 'path)
                              pth (vl-string-right-trim "\\" (vl-string-translate "/" "\\" pth))
    (if slf (vlax-release-object slf))
    (if fld (vlax-release-object fld))
    (if shl (vlax-release-object shl))
    (if (vl-catch-all-error-p err)
        (prompt (vl-catch-all-error-message err))
        pth
CodeDing
@wian.meier ,
What does your command history say when you run your lisp?
wian.meier
This is what my command history shows, only 2 of the layers have blocks drawn in, the rest of the layers are empty.
Command: TEST
.-mapexport Enter file type to export to, or ? for list <OGCKML>:OGCKML Enter name of file to create <C:\Test\0>:C:\Test\5m 100 125 pole Load Profile? [Yes/No] <No>:_N Change options  [Selection/Data/Options/Proceed] <Proceed>:_S Select objects for export [All/Manually] <All>:_ALL Enter name(s) of layer(s) to filter for objects or ? for list <*>:5m 100 125 pole Enter name(s) of class(es) to filter for objects or ? for list <*>:* Export Polygon Toplogy? [Yes/No]  <No>:_N Change options  [Selection/Data/Options/Proceed] <Proceed>:_Proceed Processing...
"4 object(s) of 4 selected, exported in 0 sec(s).
Command: .-mapexport Enter file type to export to, or ? for list <OGCKML>:OGCKML Enter name of file to create <C:\Test\5m 100 125 pole>:C:\Test\5m 150 175 pole Load Profile? [Yes/No] <No>:_N Change options  [Selection/Data/Options/Proceed] <Proceed>:_S Select objects for export [All/Manually] <All>:_ALL Enter name(s) of layer(s) to filter for objects or ? for list <*>:5m 150 175 pole Enter name(s) of class(es) to filter for objects or ? for list <*>:* Export Polygon Toplogy? [Yes/No]  <No>:_N Change options  [Selection/Data/Options/Proceed] <Proceed>:_Proceed Processing...
Command: .-mapexport Enter file type to export to, or ? for list <OGCKML>:OGCKML Enter name of file to create <C:\Test\5m 150 175 pole>:C:\Test\4F Aerial Load Profile? [Yes/No] <No>:_N Change options  [Selection/Data/Options/Proceed] <Proceed>:_S Select objects for export [All/Manually] <All>:_ALL Enter name(s) of layer(s) to filter for objects or ? for list <*>:4F Aerial Enter name(s) of class(es) to filter for objects or ? for list <*>:* Export Polygon Toplogy? [Yes/No]  <No>:_N Change options  [Selection/Data/Options/Proceed] <Proceed>:_Proceed Processing...
"0 object(s) of 0 selected, exported in 0 sec(s).
Command: .-mapexport Enter file type to export to, or ? for list <OGCKML>:OGCKML Enter name of file to create <C:\Test\4F Aerial>:C:\Test\Defpoints Load Profile? [Yes/No] <No>:_N Change options  [Selection/Data/Options/Proceed] <Proceed>:_S Select objects for export [All/Manually] <All>:_ALL Enter name(s) of layer(s) to filter for objects or ? for list <*>:Defpoints Enter name(s) of class(es) to filter for objects or ? for list <*>:* Export Polygon Toplogy? [Yes/No]  <No>:_N Change options  [Selection/Data/Options/Proceed] <Proceed>:_Proceed Processing...
Command: .-mapexport Enter file type to export to, or ? for list <OGCKML>:OGCKML Enter name of file to create <C:\Test\Defpoints>:C:\Test\0 Load Profile? [Yes/No] <No>:_N Change options  [Selection/Data/Options/Proceed] <Proceed>:_S Select objects for export [All/Manually] <All>:_ALL Enter name(s) of layer(s) to filter for objects or ? for list <*>:0 Enter name(s) of class(es) to filter for objects or ? for list <*>:* Export Polygon Toplogy? [Yes/No]  <No>:_N Change options  [Selection/Data/Options/Proceed] <Proceed>:_Proceed Processing...
CodeDing
@wian.meier ,
Thank you. If I am interpreting correctly, you are saying that you are getting 2 KML files but you are expecting 5?
wian.meier
I'm expecting only 2, but the problem is these files can't be opened in google earth. When I look at the file size of the KML/KMZ it is 1kb regardless of how many objects are placed.
It doesn't seem to be exporting the layers correctly. When I manually export the layers with
_mapexport
it works perfectly
See the attached image
CodeDing
@wian.meier ,
Can you post one of the KMZ files? I would like to see what is in it when I extract / open it with Notepad.
--Edit--
Better yet, IF you can upload a copy of the dwg file you're having issues with, I can see if the error duplicates when I try the same process.
Best,
~DD
braudpat
Hello
1) Maybe a "stupid" remark !?
2) Have you tested your DWG (+ your Lisp) with a standard/classic filename for your DWG ?
Please ONLY : A-Z , 0-9 , - , _
3) NO Space/Blank or ANY special cars !
THE HEALTH (Stay Safe), Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
