Lisp to explode multiple times.
Message 1 of 8
Can someone help me do the code.
I want to explode the following"
1. All blocks except the border with block name  "TitleBorder"
2. Explode all polylines in the drawing.
Thanks in advance.
Replies (7)
Message 2 of 8
imadHabash
you can select all what you want to explode by QSELECT or SelectSimilar commands ( watch the SEttings ) then run explode command .
Imad Habash
Message 3 of 8
Sorry but I need the fastest way since I have 1000 isometric drawings to do this. Thanks!
Message 4 of 8
RobDraw
Sounds fairly simple. What have you got so far?
Rob
Message 5 of 8
R_Tweed
As an option, you could write a script using the ssx command to create your selection set then run explode.  Use an autoscript app to run across multiple dwgs if your looking to automate.  ssx accepts wildcard input options. (*, ~, ?)
Message 6 of 8
This is what I got but it will delete all blocks.
(defun c:xblock ()
(setq ss (ssget "x" '((0 . "insert")))
c 0)
(repeat (sslength ss)
(command ".explode" (ssname ss c))
(setq c (1+ c)))
Message 7 of 8
Sea-Haven
You may want Burst rather than explode for the blocks. The code provided will not erase but explode does not save the attributes.
Also look into Aeccoreconsole this will process your 1000 dwgs there are various methods but it can automate complete directories.
A more manual approach is use a script to open explode, save and close.
Message 8 of 8
3wood
To handle a single drawing, you can try EXPLODEALL and use it in the script below.
Then you can use other tools to process multiple drawings.
(defun auto1 ()
  (explodeall (ssget "X" '((-4 . "<NOT")(2 . "TitleBorder")(-4 . "NOT>")(0 . "INSERT"))))
  (initcommandversion 2)
  (command ".explode" (ssget "x" '((0 . "LWPOLYLINE"))) "")
