Lisp to explode all blocks in model space.
MSA3DY
Message 1 of 22
MSA3DY
Hi for all.
May you help me in a lisp that explode all blocks in model space only.
I got a lisp from forum before but it exploded all blocks in model and paper space and I had a problem blocks with attributes are exploded as well.
Replies (21)
Message 2 of 22
davinatkins
I don't have a lisp for that, but you can do the same thing with quickselect.
Start the quickselect command and search for entity type "blocks". Generally, filtering by color = bylayer will grab every block.
Click ok, and then click explode.
Message 3 of 22
MSA3DY
I already do this. but need to save steps. because I make tons of changes in one day.
Message 4 of 22
devitg
@MSA3DY please upload your lsp and dwg .
Message 5 of 22
ronjonp
Message 6 of 22
Kent1Cooper
Presumably your AutoLisp routine includes something like this to find all Blocks:
(ssget "_X" '((0 . "INSERT")))
You can filter the selection to find only those in Model Space:
(ssget "_X" '((0 . "INSERT") (410 . "Model")))
and assuming the problem with Blocks with attributes is that you don't want them Exploded at all [i.e. not BURST to explode the Block parts but keep the Attribute values], you can filter for only those in Model Space without Attributes:
(ssget "_X" '((0 . "INSERT") (410 . "Model") (66 . 0)))
Kent Cooper, AIA
Message 7 of 22
paullimapa
try attached modified version
Paul Li
IT Specialist
@The Office
Message 8 of 22
jtohill
Interested in knowing why someone would want to do what you are looking to do. I am looking for how to remove explode.
Message 9 of 22
Moshe-A
@jtohill ,
there is an UNDEFINE & REDEFINE commands for that purpose.
generally users seeks for exploding xrefs, blocks, attribute blocks even polylines cause they lack of knowlege how to modify them - c'est la vie 😀
Message 10 of 22
Sea-Haven
Bricscad has a remake a block looking at matching objects, replacing with blocks. Trying to remember command.
Message 11 of 22
ronjonp
It's called 'blockify'.
Message 12 of 22
MSA3DY
it's easy, blocks prevent me from making stretch command , sometimes I have to change the entire 2 elevations with plan in one step by stretch command. in this state if the blocks are existed I have to change each block by block editor or refedit.
Message 13 of 22
Sea-Haven
Thanks ronjonp, have not needed to use it very rare to explode lots of blocks.
Message 14 of 22
MSA3DY
(ssget "_X" '((0 . "INSERT"))) , this code is great.
but I want to explode this selection
I made something like this but don't work.
(DEFUN C:xall ()
(COMMAND "explode" "_X" ""))
Message 15 of 22
paullimapa
since you actually want to select objects then don't use (ssget "X")
also remember to precede the explode command with (initcommandversion) to force explode command to work on a selection set.
EXPLODES is a full blown block selection version checking also for selected objects on locked layers prior to executing explode....enjoy...
; ExplodeS function makes Explode command on multiple objects possible when
; Explode command runs from lisp
; by using (initcommandversion) prior to the explode call
; as mentioned by BeekeeCZ (Mentor) Beekeeper CZ in
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/can-t-explode-multiple-items-with-script-file/m-p/11366987#M435204
(defun c:ExplodeS (/ ent cmdecho i IsLayerLocked lyrname menuecho ss)
;;; IsLayerLocked
;;;  Returns T if Locked
;;;        nil if Unlocked or not found
;;;        nil if lname is not a string
;;; https://www.theswamp.org/index.php?topic=888.0
 (defun IsLayerLocked (lname / ent)
  (if (and (=(type lname) 'STR)(setq ent (tblobjname "LAYER" lname)))
      (= 4 (logand 4 (cdr (assoc 70 (entget ent)))))
 ) ; end defun
  ; setup environment
  (setq
    cmdecho(getvar"cmdecho")
    menuecho(getvar"menuecho")
  (setvar"cmdecho"0)
  (setvar"menuecho"0)
  (if (setq ss (ssget '((0 . "INSERT")))) ; if insert blocks selected - note objects on locked layers not tested
    (progn
      (repeat (setq i (sslength ss)) ; loop through process of checking for objects on locked layers
       (setq lyrname (cdr(assoc 8 (entget (setq ent (ssname ss (setq i (1- i))))))))
       (if (IsLayerLocked lyrname)
        (progn
         (princ(strcat"\nBlock [" (cdr(assoc 2 (entget ent))) "] Found on Locked Layer [" lyrname "] is removed from selection."))
         (ssdel ent ss) ; remove ojbects on locked layers
       ) ; if layer is locked
      ) ; repeat
      (if (not(zerop(sslength ss))) ; test if there are objects left in selection
        (progn
         (initcommandversion) ; force explode to function with selection set
         (command "_.Explode" ss "")
      ) ; if objects in selection
      (princ(strcat"\nTotal of [" (itoa (sslength ss)) "] Block Object(s) Successfully Exploded."))
    ) ; progn
    (progn
      (princ"\nNo Block Object(s) Selected.")
    ) ; else
  ) ; if
  ; restore environment
  (setvar"cmdecho"cmdecho)
  (setvar"menuecho"menuecho)
  (princ)
) ; defun
Paul Li
IT Specialist
@The Office
Message 16 of 22
Kent1Cooper
(DEFUN C:xall ()
Your "_X" is a selection mode for use within (ssget), and not valid input for the object-selection in the Explode command.  Did you intend to put that selection into a variable?  That's an option, but not necessary -- you could do [in simplest terms to do what your code is apparently intended to do] this:
(defun C:XALL ()
  (initcommandversion); for following to Explode more than one
  (command "_.explode" (ssget "_X" '((0 . "INSERT"))) "")
But that doesn't limit itself to the current space in selection -- it will "find" all Blocks in other spaces, too, though it won't Explode them this way [if that's part of what you want to do], because commands involving object selection can "see" only objects in the same space, even though the (ssget) function can reach beyond that.  It could be made to get them all, by moving into each space in which such objects are found.
And it doesn't deal with the question of locked Layers.
Kent Cooper, AIA
Message 17 of 22
MSA3DY
Great thanks , It's working perfect.
Message 18 of 22
dean_witherden
Community Visitor
Community Visitor
Might be a bit late to the party here but will this work with blocks that are set to not be able to exploded in the block definition? I'm a surveyor and use this data to go into machine control systems  which can only handle polylines so need to explode. Don't know why these settings can't disable once the data is copied, I can't even access the setting in the block editor.
Message 19 of 22
ronjonp
@dean_witherden Run this first:
(defun c:foo nil
  (vlax-for b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
    (if	(= 0 (vlax-get b 'isxref) (vlax-get b 'islayout))
      (vla-put-explodable b -1)
  (princ)
Message 20 of 22
dean_witherden
Community Visitor
Community Visitor
Thanks @ronjonp
