Lisp to draw 3D points from 2D position and level text
dlbsurveysuk
Message 1 of 22
dlbsurveysuk
Hi, I've slightly modified some code found here https://www.cadtutor.net/forum/topic/67754-list-of-coordinate-with-nearest-text/ to produce this -
(defun c:pctt ( / points texts i j pt ind dst d result)
  (setq points (ssget "_X" (list (cons 8 "LX"))))
  (setq texts  (ssget "_X" (list (cons 0 "TEXT"))))
  (setq i 0)
  (setq result (list))
  (repeat (sslength points)
      (setq j 0)
      (setq dst nil)  ;; Closest dist.  If a new closer dist is found we replace dst by that new value
      (setq ind nil)
           (repeat (sslength texts)
               (setq d (distance
                  (setq pt (cdr (assoc 10 (entget (ssname points i)))))            ;; insert point of the point
                  (cdr (assoc 10 (entget (ssname texts j))))                            ;; insert point of the text
    	    (if (or (= dst nil) (< d dst))
	  	(progn
      	   	  (setq dst d)
      	  	  (setq ind j)
               (setq j (+ j 1))
           );repeat
         (setq result (append result (list
            (list
              (nth 0 pt)        ;; x value of point
              (nth 1 pt)        ;; y value of point
              (atof (cdr (assoc 1 (entget (ssname texts ind)))))                    ;; text to number ?
    (setq i (+ i 1))
  );repeat
         (if result
             (foreach xyzlist result
                   (command "POINT" xyzlist)
                   (princ xyzlist)
(princ )
The idea is to draw 3d points at all cross insertions, that have a z value of the nearest text.
Test drawing attached.
The command line output shows the correct z values but the drawn points all have z=0.
I can't see what is wrong. I'm sure it's something obvious that I'm missing...
Thanks.
Accepted solutions (3)
Replies (21)
Message 21 of 22
dlbsurveysuk
OK that makes sense now. Thanks again.
Message 22 of 22
komondormrex
you are welcome)
