Lisp to do automatic dimensions aligned and arc from polyline length
olucasrossetti
Observer Observer
Message 1 of 12
olucasrossetti
Observer
Observer
Hello everybody!
I wonder if anyone can help me modify this lisp.
It works fine as you can see in the image below. But I need to quantify these values, and when I use a sum lisp an error happens.
Basically because arc dimensions are actually "angular dimensions".
Can someone help me?
(defun c:cpaut
	      (/		2nd_point
	       deriv_at_point	ent_bulge
	       ent_closed	ent_entget
	       ent_layer	ent_temp_open
	       line_pt1		line_pt2
	       mdim_clocktest	mdim_counter
	       mdim_curdimscal	mdim_curlay
	       mdim_curluprec	mdim_curosmode
	       mdim_dan		mdim_enttemp
	       mdim_enttemp2	mdim_pline_ent
	       mdim_pline_ent_vla
	       mdim_pline_pts	mdim_pt1
	       mdim_pt2		mdim_scale
	       mdim_scale_dist	mdim_x
	       mdim_x1		mdim_y
	       mdim_y1		midpoint_at_curve
	       param_at_point	ron1
	       ron2		x
	       *error*
;;;load vla functions
  (vl-load-com)
;;;error trap
  (defun *error* (msg)
    (command "._undo" "_end")
    (setvar 'clayer mdim_curlay)
    (setvar 'dimscale mdim_curdimscal)
    (setvar 'luprec mdim_curluprec)
    (setvar 'osmode mdim_curosmode)
    (setvar 'cmdecho 1)
  ) ;_ end_defun
;;;subroutine to reverse polyline by use of pedit command
  (defun mdim_revpoly (selected_pline)
    (setq mdim_pt1
	   (vlax-curve-getendpoint
	     (vlax-ename->vla-object selected_pline)
	   ) ;_ end_vlax-curve-getendpoint
    ) ;_ end_setq
    (setq mdim_y (cadr mdim_pt1))
    (setq mdim_x (car mdim_pt1))
    (setq mdim_x1 (+ mdim_x 100))
    (setq mdim_y1 (+ mdim_y 100))
    (setq mdim_pt2 (list mdim_x mdim_y1))
    (setvar 'clayer ent_layer)		; set the original layer
    (command "line" "NON" mdim_pt2 "NON" mdim_pt1 "")
    (setq mdim_enttemp (entlast))
    (command "pedit" mdim_enttemp "y" "j" selected_pline "" "")
    (setq mdim_enttemp2 (entlast))
    (command "break" mdim_enttemp2 "NON" mdim_pt1 "NON" mdim_pt1) ;_ end_command
    (entupd mdim_enttemp2)
    (command "erase" mdim_enttemp2 "")
    (setq mdim_pline_ent (ssget "l"))	; store new entity to reset the selection set
    (setq mdim_pline_ent_vla		; reset the vla-object
	   (vlax-ename->vla-object (ssname mdim_pline_ent 0))
    ) ;_ end_setq
    ;;reset the polyline coordinates
    (setq mdim_pline_pts
	   (mapcar
	     '(lambda (x) (trans x 0 1))
	     (mapcar
	       'cdr
	       (vl-remove-if-not
		 '(lambda (x) (= 10 (car x)))
		 (entget
		 ) ;_ end_entget
	       ) ;_ end_vl-remove-if-not
	     ) ;_ end_mapcar
	   ) ;_ end_mapcar
    ) ;_ end_setq
  ) ;_ end_defun
;;;initialization
  (setvar 'cmdecho 0)
  (command "._undo" "_begin")
  (setq mdim_curlay (getvar 'clayer))
  (setq mdim_curdimscal (getvar 'dimscale))
  (setq mdim_curluprec (getvar 'luprec))
  (setq mdim_curosmode (getvar 'osmode))
  (setvar 'osmode 0)
  (command
    "Layer" "m"	"DIMS" "unlock"	"DIMS" "thaw" "DIMS" "on" "DIMS" "c" "6" "DIMS"	"") ;_ end_command
 ;_ end_command
 ;_ end_command
;;;user input function by Cab used to set dimscale
  (while
    (progn
      (setq mdim_scale
	     (cond ((getint "\nEnter the drawing scale [20/30/50] <50>: "))
		   (50)
	     ) ;_ end_cond
      ) ;_ end_setq
      (if (not (vl-position mdim_scale '(1 20 30 50)))
	(not
	  (prompt "\nChoose only from 20 30 & 50, please re-enter.")
	) ;_ end_not
      ) ;_ end_if
    ) ;_ end_progn
  ) ;_ end_while
  (cond
    ((= mdim_scale 1) (setq mdim_scale_dist 1))
    ((= mdim_scale 20) (setq mdim_scale_dist 140))
    ((= mdim_scale 30) (setq mdim_scale_dist 210))
    ((= mdim_scale 50) (setq mdim_scale_dist 350))
  ) ;_ end_cond
  (setvar 'dimscale mdim_scale)
;;;Pick Entity
  (while
    (not
      (setq
	mdim_pline_ent
	 (ssget ":E:S" '((0 . "LWPOLYLINE")))
      ) ;_ end_setq
    ) ;_ end_not
     (princ "\nMISSED....PICK AGAIN")
  ) ;_ end_while
  (setq mdim_pline_entname (ssname mdim_pline_ent 0))
  (setq ent_layer (cdr (assoc 8 (entget mdim_pline_entname)))) ; store the original layer
	 (mapcar
	   (mapcar
	     'cdr
	     (vl-remove-if-not
	       (entget
	       ) ;_ end_entget
	   ) ;_ end_mapcar
	 ) ;_ end_mapcar
  ) ;_ end_setq
;;;subroutine for clockwise/counterclockwise test, author LE,fatty(not sure)?
  (defun clockwise-p (p1 p2 p3)
    (< (sin (- (angle p1 p3) (angle p1 p2))) -1e-14)
  ) ;_ end_defun
;;;If selected polyline is closed, get the bulge at the end segment, then open it by
;;;setting dxf code 70 to 0.  Set Ent_temp_open to T to flag that the polyline is temporarily
;;;opened
  (if (= (setq ent_closed
		(cdr (assoc 70 (entget mdim_pline_entname)))
	 ) ;_ end of setq
	 1
      ) ;_ end of =
    (progn
      (setq ent_bulge
	     (vla-getbulge
	       (vlax-ename->vla-object mdim_pline_entname)
	       (1-
		 (vlax-curve-getendparam
		 ) ;_ end_vlax-curve-getendparam
	       ) ;_ end_1-
	     ) ;_ end_vla-getbulge
      ) ;_ end_setq
      (setq ent_entget (entget mdim_pline_entname))
      (if (not (Setq mdim_clocktest
		      (clockwise-p
			(car mdim_pline_pts)
			(cadr mdim_pline_pts)
			(caddr mdim_pline_pts)
		      ) ;_ end_clockwise-p
	       ) ;_ end_Setq
	  ) ;_ end_not
	(progn
	  (entmod (subst (cons 70 0) (assoc 70 ent_entget) ent_entget))
	  (setq ent_temp_open t)
	) ;_ end_progn
      ) ;_ end_if
    ) ;_ end_progn
;;;    (if	(equal
;;;	  (vlax-curve-getpointatparam
;;;	    (vlax-ename->vla-object mdim_pline_entname)
;;;	    (vlax-curve-getendparam
;;;	    ) ;_ end_vlax-curve-getendparam
;;;	  ) ;_ end_vlax-curve-getpointatparam
;;;	    (vlax-curve-getstartparam
;;;	    ) ;_ end_vlax-curve-getstartparam
;;;	) ;_ end_equal
;;;      (progn(setq ent_entget (entget mdim_pline_entname))
;;;      (entmod (subst (cons 70 1) (assoc 70 ent_entget) ent_entget))
;;;      (setq ent_orig_open 1))
;;;    ) ;_ end_if
  ) ;_ end_if
;;;after Selected Polyline is now open or temporarily open, there are cases that end point
;;;and start point of the polyline lies in the same coordinates even it is open already.
;;;Remedy is to break the polyline at the last segment and delete the small segment
;;;to make it completely open.
  (setq mdim_pline_ent_vla (vlax-ename->vla-object (ssname mdim_pline_ent 0)))
  (if (and (equal
	       mdim_pline_ent_vla
		 mdim_pline_ent_vla
	       mdim_pline_ent_vla
		 mdim_pline_ent_vla
	   ) ;_ end_equal
		       (clockwise-p
		) ;_ end_Setq
	   ) ;_ end_not
      ) ;_ end_and
    (progn
      (command
	"break"
	mdim_pline_entname
	"non"
	  mdim_pline_ent_vla
	  (1- (vlax-curve-getendparam
		mdim_pline_ent_vla
	  ) ;_ end_1-
	"non"
	  mdim_pline_ent_vla
		mdim_pline_ent_vla
	  ) ;_ end_1-
      ) ;_ end_command
      ;;after breaking, get the bulge of the small segment, to restore it later
      (setq ent_bulge
	     (vla-getbulge
	       (vlax-ename->vla-object (entlast))
	       (1-
		 (vlax-curve-getendparam (vlax-ename->vla-object (entlast)))
	       ) ;_ end_1-
      ) ;_ end of setq
      (entdel (entlast)) ;_ delete the small entity to make polyline completely open
    ) ;_ end_progn
  ) ;_ end_if
;;;test if the selected polyline is clockwise/ counterclockwise. If counterclockwise,
;;;run mdim_revpoly subroutine to reverse polyline direction.
;;;There is a need to reverse polyline coordinates in order to place dimensions on
;;;the correct side of polyline
  (if (not
	       (clockwise-p
	) ;_ end_Setq
      ) ;_ end_not
    (mdim_revpoly (ssname mdim_pline_ent 0))
  ) ;_ end_if
;;;begin processing each segment
;;;mdim_counter is the parameter counter
  (setq mdim_counter 0)
  (while
    (< mdim_counter
       (fix
	 (vlax-curve-getendparam mdim_pline_ent_vla)
       ) ;_ end_fix
    ) ;_ end_<
     (setq line_pt1 ;_startpoint at segment
	    (vlax-curve-getpointatparam mdim_pline_ent_vla mdim_counter)
     ) ;_ end_setq
     (setq line_pt2 ;_endpoint at segment
	      mdim_pline_ent_vla
	      (1+ mdim_counter)
     ) ;_ end_setq
     (command "._layer" "s" "DIMS" "") ;_set layer to dims
     ;;if  bulge at segment is 0.0 then it is straight
     (if (= (vla-getbulge mdim_pline_ent_vla mdim_counter) 0.0)
       ;;if it is straight perform simple dimaligned
       (progn
	 (princ "\nstraight")
	 (command
	   "._dimaligned"
	   "non"
	   line_pt1
	   "non"
	   line_pt2
	   "non"
	   (polar
	     line_pt2
	     (+ (angle line_pt1 line_pt2) (/ pi 2))
	     mdim_scale_dist
	   ) ;_ end_polar
	 ) ;_ end_command
       ) ;_ end_progn
       ;;if it is curved get the midpoint of curve
       (progn
	 (princ "\ncurve")
	 (setq midpoint_at_curve ;_midpoint of curve
		(vlax-curve-getpointatdist
		  mdim_pline_ent_vla
			(vlax-curve-getdistatparam
			  mdim_pline_ent_vla
			  (1+ mdim_counter)
			) ;_ end of vlax-curve-getdistatparam
			  mdim_pline_ent_vla
			  mdim_counter
		      ) ;_ end of -
		      0.5
		    ) ;_ end of *
		    (vlax-curve-getdistatparam mdim_pline_ent_vla mdim_counter)
		  ) ;_ end of +
		) ;_ end of vlax-curve-getpointatdist
	 ) ;_ end of setq
	 ;;Get parameter at midpoint of curve
	 (setq param_at_point
		(vlax-curve-getparamatpoint
		  mdim_pline_ent_vla
		  midpoint_at_curve
		) ;_ end of vlax-curve-getparamatpoint
	 ) ;_ end of setq
	 ;;Get derivative at midpoint of curve
	 (setq deriv_at_point
		(vlax-curve-getfirstderiv
		  mdim_pline_ent_vla
		  param_at_point
		) ;_ end of vlax-curve-getfirstderiv
	 ) ;_ end of setq
	 (setq 2nd_point (mapcar '+ midpoint_at_curve deriv_at_point)) ;_ this is for getting angle at curve's midpoint
	 (command
	   "._dimangular"
	   "" ;_3point vertex
	   ;; snap to center of curve based on curve's midpoint
	   (osnap (vlax-curve-getpointatparam
		    mdim_pline_ent_vla
		    param_at_point	;(1+ mdim_counter)
		  "_cen"
	   ) ;_ end_osnap
	   line_pt1 ;_ startpoint of segment
	   line_pt2 ;_ endpoint of segment
	   "non"
	   (polar
	     midpoint_at_curve
	     (+ (angle midpoint_at_curve 2nd_point) (/ pi 2))
 ;_angle at curve's midpoint rotated by 90deg.
	     mdim_scale_dist
	   ) ;_ end_polar
	 ) ;_ end_command
	 ;;store dimension object
	 (setq mdim_dan (vlax-ename->vla-object (entlast)))
					;(setvar 'luprec 0)
	 ;;begin dimension override
	 (vla-put-TextOverride
	   mdim_dan
	   (rtos
	     (-	(Setq ron1 (vlax-curve-getdistatparam
			     mdim_pline_ent_vla
			     (1+ mdim_counter)
			   ) ;_ end_vlax-curve-getdistatparam
		(Setq ron2 (vlax-curve-getdistatparam
			     mdim_pline_ent_vla
			     mdim_counter
		) ;_ end of Setq
	     ) ;_ end_-
	     2
	     0
	   ) ;_ end_-
	 ) ;_ end_-
       ) ;_ end_vla-put-TextOverride
     ) ;_ end_progn
     (setq mdim_counter (1+ mdim_counter))
  ) ;_ end_while
;;;if ent_temp_open is T, then we need to close the polyline since it is closed originally
  (if ent_temp_open
    (progn
		     (assoc 70 (entget (ssname mdim_pline_ent 0)))
	      ) ;_ end of subst
      ) ;_ end of entmod
      ;;restore the original bulge of the last segment
      (if (/= ent_bulge 0.0)
	(progn
	  (vla-setbulge
	    mdim_pline_ent_vla
	    (1- (vlax-curve-getendparam mdim_pline_ent_vla))
	    (* ent_bulge -1) ;_ to reverse the direction of bulge
	  ) ;_ end_vla-setbulge
	  ;;get the mipoint of curve at last segment
		   mdim_pline_ent_vla
			   mdim_pline_ent_vla
			   mdim_pline_ent_vla
		       ) ;_ end of -
		       0.5
		     ) ;_ end of *
		       mdim_pline_ent_vla
		   ) ;_ end_+
		 ) ;_ end_vlax-curve-getpointatdist
	  ) ;_ end_setq
	  ;;get parameter at midpoint of curve (last segment)
		   mdim_pline_ent_vla
		   midpoint_at_curve
	  ) ;_ end of setq
	  ;;get derivative at midpoint of curve (last segment)
		   mdim_pline_ent_vla
		   param_at_point
	  ) ;_ end of setq
	  ;;put dimension at last segment of curve
	  (command
	    "._dimangular"
		     mdim_pline_ent_vla
		     param_at_point
		   "_cen"
	    ) ;_ end_osnap
	      mdim_pline_ent_vla
	      mdim_pline_ent_vla
	    "non"
	    (polar
	      midpoint_at_curve
	      mdim_scale_dist
	    ) ;_ end_polar
	  ) ;_ end_command
					;(setvar 'luprec 0)
	    mdim_dan
	    (rtos
	      (- (Setq
			  mdim_pline_ent_vla
		 (Setq ron2
			  mdim_pline_ent_vla
			  ) ;_ end of 1-
		 ) ;_ end of Setq
	      ) ;_ end_-
	      2
	      0
	    ) ;_ end_rtos
	) ;_ end_progn
	;;Else, if last segment if straight, put dimension on last segment
	(command
	  "._dimaligned"
	  "non"
	    mdim_pline_ent_vla
	  "non"
	    mdim_pline_ent_vla
	  "non"
	  (polar
	      mdim_pline_ent_vla
	    (+ (angle (vlax-curve-getpointatparam
			mdim_pline_ent_vla
			mdim_pline_ent_vla
	       ) ;_ end_angle
	       (/ pi 2)
	    ) ;_ end_+
	    mdim_scale_dist
	  ) ;_ end_polar
	) ;_ end_command
      ) ;_ end_progn
    ) ;_ end_if
  ) ;_ end of if
  (*error* "")				; force error trap
  (princ)
) ;_ end_defun
(princ)
Replies (11)
Message 2 of 12
calderg1000
Regards @olucasrossetti
The routine works well for dimensioning polyline sections. How do you want to do the quantification...?
In the properties you can see the total length...
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 3 of 12
olucasrossetti
Observer
Observer
hello @calderg1000 !! Thx for replying.
I have a lisp that do this sum for me. So i need to select many dims i want and then the lisp plot a mtext with totals.
But the dimensions need to have a lenght. In that case this lisp do angular dimensions and replace the angle text for the lenght text and it doesnt work for my sum lisp 😕
Message 4 of 12
Sea-Haven
Arc length = rad*ang what is hard about that ?
Message 5 of 12
calderg1000
Dear @olucasrossetti
I just saw the result of the arc measurement. it effectively replaces the length with some text.
I'm going to check where to make the change, I hope to give myself some time. Hope someone can do it faster.
Carlos Calderon G
Message 6 of 12
Kent1Cooper
If what you are after is the lengths along arc segments, rather than their angles, in recent-enough versions there is now a DIMARC command that gives that length, which you may be able to use, instead of using DIMANGULAR with an imposed text-content override.  DIMARC Dimensions store that length in the same way as DIMALIGNED ones do [in the DXF 42 entry in entity data, or the "Measurement" property in both VLA Properties and (getpropertyvalue) terms], so summing them would not require handling the two kinds any differently.  Could you use DIMARC's instead of DIMANG's for the arc segments?  They do have the drawback that their look varies with the arc's swept angle, with parallel instead of radial extension lines when that is under 90°:
But as much as I dislike that difference, it is at least clear what the measurement is, so if you can live with that, summing would be as easy as if all were DIMALIGNED ones.
Kent Cooper, AIA
Message 7 of 12
devitg
@olucasrossetti
Why not to use
 _dimarc
Select arc or polyline arc segment:
Instead DIMANGULAR
Message 8 of 12
Kent1Cooper
@olucasrossetti wrote:
.... I need to quantify these values, and when I use a sum lisp an error happens.
Basically because arc dimensions are actually "angular dimensions". ....
Can you post the "sum lisp"?  It may be possible to have it just convert the text override to a number for only those Dimensions that have a text override, and use that in the sum.
And how are you using it?  Do you select all the Dimensions yourself to sum up, or would you prefer to have it done automatically when you do the Polyline-Dimensioning routine?
By the way, your routine seems [in a quick overview -- I didn't study it deeply] overly complicated about a lot of things.  For example, to determine whether a Polyline is closed, which you can do with the (vlax-curve-isClosed) function, and for reversing the Polyline [which shouldn't be necessary], which you can do with a REVERSE command.  For one that takes less than a quarter of the number of lines of code, try DimPoly.lsp, >here<.  You would presumably use the DPO command that it defines [= Dimension Polyline on the Outside].  Its origins predate the DIMARC command, so it also uses ANGular Dimensions, and overrides their text with the length, which means summing up would need the same kind of adjustment to those overridden ones as for your routine.  [Maybe I'll try making a version that uses DIMARC so no override is needed.]
Kent Cooper, AIA
Message 9 of 12
Sea-Haven
REVERSE command is not supported in Bricscad V20 maybe latest version, but again a simple method Pedit ent R. Works in Acad and Bricscad.
Message 10 of 12
khanh_nhoc_58
Community Visitor
Community Visitor
I want to dim it close to the curve, can you help?
Message 11 of 12
Sea-Haven
Did you read Kent's suggestion about Dimarc ? You just need a dim style with the line work turned off. Can use then with DIM aligned as well.
Message 12 of 12
Kent1Cooper
Find this part in the code:
  (cond
  ) ;_ end_cond
and reduce those 140/210/350 numbers.
Kent Cooper, AIA
