Lisp to copy mtext to clipboard in one step
mpa-la
Message 1 of 42
mpa-la
Can anyone direct me to a lisp that will copy all the text inside an mtext entity by clicking on the entity, so that I can paste it into excel?  I grow tired of double clicking the text, ctrl A, ctrl C, then ctrl V into Excel.  Just want to cut down the number of keystrokes for something I have to do a lot.  Thanks!
Replies (41)
Message 41 of 42
mhy3sx
Hi Sea-Haven. I use this code to copy a part of mtext and paste it inside other mtext so Stripmtext will not Help.
Is it possible to combine  Stripmtext command with this
(defun c:foo( / en tx html)
  (and (setq en (ssget ":S" '((0 . "*MTEXT"))))
       (setq en (ssname en 0))
       (setq en (vlax-ename->vla-object en))
       (vlax-property-available-p en 'textstring)
       (setq tx (vla-get-textstring en))
	    (setq tx (substr tx 1 (1- (vl-string-search "=" tx))))
       (vlax-invoke (vlax-get (vlax-get (setq html (vlax-create-object "htmlfile")) 'ParentWindow) 'ClipBoardData) 'setData "Text" tx)
       (vlax-release-object html)
  (princ)
and the paste text be clear from all formatting?
Message 42 of 42
Sea-Haven
Look at  UnFormat String | Lee Mac Programming (lee-mac.com)
You have
 So
(setq tx (LM:UnFormat tx T))
At start of code
(if (not LM:UnFormat)(load "Lee-Mac-unformat"))
You need to save the lisp into a support directory with a name as suggested.
